03-27-2009, 09:10 AM | #1 |
Newbie Join Date: Jan 2008 Location: State College
| Project Rock Beetle: AX10 comp build Project Rock Beetle: AX10 comp build These are the first mock up pictures so go easy on me, many things may be changed because I have a lot of different ideas I want to try, some will work some wont. Here is the list so far. 1: AX10 ARTR (don’t know why I bought this I haven’t used a lot of the stock parts) 2: R2 trans w/dig (customized) 3: 3PM 2.4 4: Sidewinder ESC 5: T-Maxx drive shafts 6: 2200KV brushless motor (customized) 7: Masher 2000 M3 & M2 6” (customized) 8: HPI Bug Body 9: Hitec servos HS 5645MG / HS 85MG x2 10: CC BEC 11: Integy steering knuckles 12: Axial adjustable Cs 13: 4.30:1 ring & pinion (customized) 14: HPI Wheely King front axle shafts (customized) 15: 11.1 1300 25c lipo 16: many custom aluminum billet parts and stainless hardware What I have accomplished so far. 45 degrees of steering with 6” tires, compact simple BTA steering, 0 degrees ackerman, fornt axle tube wideners, front motor mounted R2, magic front diff, composite links, mini servo spring loaded dig, 4.30:1 R&P. What I am still working on. locking front & rear diffs, adjustable 4 link suspension, inverted internal spring lower link mounted front shocks, custom lower skid plate. |
03-27-2009, 09:16 AM | #2 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
I wouldn't mind seeing a pic of the ring and pinion.
03-27-2009, 09:22 AM | #3 |
Pebble Pounder Join Date: Jul 2008 Location: Anderson
The first picture looks to be a really heavy rig!!!! And not sure how far you are going to get with 6inch tires in a comp... But looks good so far!!!
03-27-2009, 09:40 AM | #4 |
Here's your pic Gunnar. The 6" tires make it look heavy, will they work? dont know yet, time will tell. Last edited by MKDU2; 04-09-2009 at 02:14 PM. Reason: typo |
03-27-2009, 09:44 AM | #5 |
Cool thanx, "velli interesting"
03-27-2009, 10:08 AM | #6 |
03-27-2009, 11:14 AM | #7 |
Yup there ya go. Cool rock...
03-30-2009, 08:00 AM | #8 |
| Here are some better pics of the front axle. |
04-02-2009, 09:19 AM | #9 |
I like the axle-end reinforcement. May I ask how is it attached? Also would like to know how you will run your link/shock setup? Very interested in this build, and you are doing very good work so far |
04-02-2009, 09:59 AM | #10 | |
The end reinforcements that you are referring to are actually axle widening spacers that increase the front width by 1.25", they will be attached with button head 3mm screws (I just haven't drilled them yet). I am using custom axle shafts and a special front locking diff so I needed a little extra room, the bonus was it gave me more space for the BTA steering and battery mount. I am still working on the link and shock set up, Zero ackerman steering for you AX-10 | |
04-02-2009, 10:25 AM | #11 |
Funny, I had two ideas as I was contemplating on how my front end was going to be on my build. At first, I really wanted BTA, but knew that shock and servo placement was going to be a problem. When I decided to build my 4 link mount, I changed back to front steering, but wanted max steering angles, so moving the shocks was my next problem. My first idea was to make up an offset lower mount. My second idea was to mount the shocks on the links, pretty much like your proposed set up, by running the shock end in-line with the link. I just didn't think it would be strong enough to survive a big tumble, and not move the shocks inboard enough, so I chose not to do that, by using larger hardware(8-32 on my lower links now) it would be fine, but I just took the easy way out. Great thinking on your part.
04-02-2009, 11:38 AM | #12 |
| Here are a couple more pictures of the 4link system I am working on. The upper link mount will be tied into the servo/battery plate with a bolt on top plate, the pic shows the mod. Also I am not happy with my first mount I have made (to thin at the mounting holes) but it shows how I will mount the 4link. |
04-02-2009, 12:10 PM | #13 |
Newbie Join Date: Mar 2009 Location: Riverside
Great Build So far looks awesome... |
04-03-2009, 12:55 PM | #14 |
| Thanks much robert. Here a a couple more pictures of my fist idea for a small TVP side mount R2 trans setup, ( just a thin prototype not final design) if i am not happy with the stock AX10 I will continue to work on it a bit more. Also a shot of my composit link design and custom diff. |
04-03-2009, 04:44 PM | #15 |
Quarry Creeper Join Date: May 2005 Location: Crossville,TN
This is a really great build with some very innovative ideas. Excellent job so far. Carl |
04-03-2009, 05:26 PM | #16 |
Quarry Creeper Join Date: Dec 2008 Location: Fraggle Rock
Very interesting. I like it,,,,A lot! |
04-09-2009, 10:03 AM | #17 |
| Thanks to all for the kind words and keeping me motivated, it seems like I have been working on this forever (snow ball effect). And so it looks like I will be making my own frame after all, I just could not make the stock frame do what I wanted (adjustably and shock location) with out butchering it up. Now I am on version 1.07 and more than likely there will be a version 1.08 before I am satisfied with it. The front 4-link is working out good so far, the only issue I have is with the front lower right link/motor clearance, (V1.08 TVP) I still have room to move the lower links around a bit and if I run a shorter out runner motor this should solve my clearance issue, (any one heard if Holmes Hobbies has the sensored out runner ready yet ?) thats all I have for now, back to work! |
04-09-2009, 11:32 AM | #18 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
good ideas, who says people in 2.2 dont "build" it. Keep it up and looks like you may need a vendor star |
04-21-2009, 07:05 AM | #19 |
| Here is a link to a few more suspension and drive line pictures http://www.rccrawler.com/forum/showpost.php?p=1717029&postcount=27, from now on I will try to keep all the info on this project on this thread instead of posting bits and pieces in other areas. |
04-21-2009, 09:06 PM | #20 |
Pebble Pounder Join Date: Sep 2008 Location: albuquerque
nice build. those hpi's look so sick with that body. cant wait to see thios truck when its done.
