04-02-2009, 02:47 AM | #21 | |
04-02-2009, 09:11 AM | #22 |
Newbie Join Date: Jan 2008 Location: State College
| Nice Job am4x4 on the use of stock parts with just some bolt on adjustment plates, also I like your parallel steering linkage. |
04-02-2009, 09:18 AM | #23 |
| This is what I am going to try to make work, the pictures are only crude mock ups but I am pretty sure I can make it work with out bind or interference problems.
04-02-2009, 10:41 AM | #24 |
Quarry Creeper Join Date: Sep 2008 Location: Kuala Lumpur, Malaysia
I too have tried to design a BTA set-up and ran into major clearance issues with the little bracket that fits around the pinion and supports the upper link and servo bracket. I see you have left it off, and your servo bracket is supported by only two plastic posts above the pumpkin. Do you think they are strong enough and rigid enough? I would be a little concerned myself. I also see those wideners between the axle housing and the 'C's. That looks like it will keep the tires off the links and springs, and give clearance for the steering arms and lower link mounting tabs, but what is the track width now? Looks like about 11 1/2" or so? Did you make your own longer half shafts for that? Just looks like a lot of change and compromise to get a BTA linkage in there. Cheers. |
04-02-2009, 11:50 AM | #25 | |
See this post for more info on this project http://www.rccrawler.com/forum/showt...79#post1715379 And yes the axles are modified Wheely King's. | |
04-02-2009, 06:53 PM | #26 | |
Rock Stacker Join Date: Jan 2009 Location: simi valley, ca
I am kinda new at all of this but what front shafts will take 45deg. My stock ones maxed at around 32deg | |
04-03-2009, 07:24 AM | #27 | |
What I did was modified some Wheely King axles (they have a larger ball on the end, smaller throat, longer overall length and a smaller pin) and I shortend the stub axle cup (stock AX10) and reground the inner angle to 45 degrees. Axle specs. stock AX10 1. length-77mm 2. ball end-5.77mm 3. throat-3.4mm 4. pin- 2.5mm Wheely King 1. length- 84.6mm 2. ball end- 6.2mm 3. throat- 3.1mm 4. pin- 2mm mod axle 1. length-94mm 2. ball end-6.2mm 3. throat- 3.1mm 4. pin- 2.5mm ( sorry for the crappy pictures I need a better camera) | |
04-03-2009, 03:17 PM | #28 |
MKDU2, nice work on the axle shafts. Any comments on the wideners? am4x4, also sorry if this is getting off your topic but I also would love a good BTA set-up and more steering angle. Cheers. |
04-03-2009, 05:54 PM | #29 | |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
Axial cvd's-1.5mm cross pin 3racing-2.0mm cross pin RC4WD-not quite out yet, pin size unknown, supposed to be beefy All those axles will do 45 degrees. I have modded 3Racing axles to use 3/32" pins(2.36mm) I have 2.5mm pins on order to try also. | |
04-03-2009, 09:55 PM | #30 | |
What info are you interested in on the wideners? There is a bit more info on the build thread here, Project Rock Beetle: AX10 comp build | |
04-04-2009, 09:44 AM | #31 |
MKDU2, thanks for the link, that answers my queries. Cheers. |
05-13-2009, 01:57 PM | #32 |
Newbie Join Date: Apr 2009 Location: Ljubljana
i'm planning to buy the venom creeper. I need it for my robotics project, so it has to be very maneuverable. Is it possible to buy another front axle and mount it on the rear, so i would have 4 wheel steering? please reply! |
05-13-2009, 02:59 PM | #33 |
Maybe you should check out the venom creeper section of the forum. More likely to get a response there. IMO a ax-10 would be the better option as the kit one already hads provisions for rear steer. As far as turning while moving forward, a dig is by far the best option. When properly setup it'll turn on the inside rear tire.
06-04-2009, 04:43 PM | #34 |
Quarry Creeper Join Date: Sep 2008 Location: Isle of Man
06-04-2009, 11:07 PM | #35 |
06-07-2009, 07:38 AM | #36 |
MKDU2, I'm curious about the spacer between the end of the axle housing and the 'C'. Did you lengthen the axle housing?
08-14-2009, 09:13 AM | #37 |
Pebble Pounder Join Date: Jun 2009 Location: Jackson
Thanks for the post
02-08-2010, 06:50 PM | #38 |
Quarry Creeper Join Date: Jan 2010 Location: Rocky Hill
| Zero akerman will be the first mod to my ax10! Thanks! |
02-09-2010, 04:14 AM | #39 | |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
I run Egressors zero ackerman V5's and I have Uber steering | |
02-09-2010, 04:16 AM | #40 |
Quarry Creeper Join Date: Jan 2009 Location: Bay City
| Egressors
Where did you get those?
