07-08-2009, 01:18 AM | #41 |
160* does sound really hot... but running 9V to it is probably part of it. Maybe you should try turning down your BEC little by little until you can run the minimum BEC voltage necessary for everything to work.
07-08-2009, 09:27 AM | #42 |
Ya, that's way too hot, it won't last long at those temps I would say. First things first, are your endpoints set correctly? Any binding in the linkage/steering assembly? Now, the higher voltage input is going to make it run hotter than normal for sure.
07-08-2009, 12:35 PM | #43 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
Thats what I was afraid off. Just annoying you got to unsolder the BEC each time just to change a setting. *bangs head on wall* lol. I'm on call this week so guess that gives me something to do while i'm stuck at home
07-08-2009, 09:16 PM | #44 | |
I think you should contact Castle and tell them to come up with a updated version that would have say, another plug just for tuning.... Then when they put it into production, have them cut you a check, and I'll take 50% | |
07-08-2009, 09:18 PM | #45 |
Wait, you're running 9 volts to a 780? The thing does 423 ounces @ 6 volts! |
07-08-2009, 10:27 PM | #46 | |
Ex: If I steering eratically left to right, my throttle would suddenly engage for a second. After I upped the voltage it went away. From what I've been told by setting it at 9V your not pumping 9V into the servo, instead your allowing the servo to use 9V if it needed too.. Am I being mislead? | |
07-08-2009, 10:36 PM | #47 |
Hateraide Join Date: Dec 2008 Location: Mission BC
From what i understand is w.e you have your bec set to that is how much power is allowed through to your servo, someone might be able to clear that up more but i beleive thats how it work
07-16-2009, 09:56 PM | #48 |
Well, I haven't ran it for awhile, nor have I changed my BEC Settings, but I did do a complete tear down to relube, clean and look for any pre-mature breakage issues. These Axial CVD's have some seriously nasty slop. I've never seen anything with so much slop and I can't recall them having them when they were new but I never paid attention till now. Do you guys find yourselfs replacing them after some time due to wear or is this slop normal?
07-17-2009, 05:46 AM | #49 |
Quarry Creeper Join Date: Jun 2008 Location: Sykesville MD
The CVD's are a liability. They should not have any slop. Check this tread for all you never wanted to know about the CVD's. Broke Axial CVD |
08-20-2009, 07:22 PM | #50 |
08-27-2009, 08:40 PM | #51 |
Newbie Join Date: Jul 2009 Location: california
is it plastic if so why pay 100$$ imp
08-27-2009, 09:31 PM | #52 |
| Ouch, thats like calling a real rc a tyco.. The SSS chassis is more then just plastic, it eliminates the use of shocks and allows you to tune your crawlers suspension by moving your links into different locations. Being made out of delin (not to be confused with ordinary plastic) its relatively strong, yet slick allowing you to slide across the rocks and its slighter then most options out there. Its one sweet chassis |
08-27-2009, 10:29 PM | #53 |
ya was going to order it but wow how long tell it is going to brake
08-27-2009, 11:40 PM | #54 | ||
Quarry Creeper Join Date: Aug 2008 Location: Yes yes, it is.
08-28-2009, 07:10 PM | #55 |
well ok still wondering how plastic cost 100 bucks but i guess no one hase had problums
08-28-2009, 07:39 PM | #56 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
Sure, I broke a side plate in a few days, but it's been replaced and the chassis is doing good, even after a few weeks of good thrash sessions. Your not just paying for "plastic" your also paying for the hours of design, prototyping, and testing. Of course, you could just buy some plastic and copy the chassis, but will it work the first time? The second? How long will it take you to make it? Will you use a CNC machine? Hacksaw and files? You'll start finding out how much the chassis is worth when you run it.
08-28-2009, 08:18 PM | #57 |
okok
