02-10-2010, 09:29 PM | #1 |
Rock Stacker Join Date: Dec 2009 Location: Fremont
| Updated...Axial BTA with four link Dad just installed my new BTA and still used my front four link( had to mod the STRC servo mount)..also installed a slash slipper and new pink fade Bug body Last edited by crawling qeen; 02-10-2010 at 10:43 PM. Reason: spelling |
02-10-2010, 09:34 PM | #2 |
RCC Addict Join Date: Oct 2008 Location: PA
Looks sweet! Did you use the Axial battery/servo tray?
02-10-2010, 09:38 PM | #3 |
| Dad used the STRC one..the Axial one is set up for three link |
02-10-2010, 09:39 PM | #4 | |
Also, what are the dimensions of your battery? Sorry for the questions, I'm planning out a similar setup for mine. Thanks! | |
02-10-2010, 09:46 PM | #5 |
Newbie Join Date: Jul 2009 Location: Santa Rosa
i need to invest with a BTA, what kit did you buy and how much? was gettin hungup lesser of a problem? |
02-10-2010, 09:46 PM | #6 |
| 2 5/8" long 1 1/4" wide 3/4 " tall |
02-10-2010, 09:48 PM | #7 |
02-10-2010, 09:54 PM | #8 |
02-11-2010, 12:47 AM | #9 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
Very cool girl! Are ya and the old man gonna make it to folsom in larch for the ncvrcc comp?
02-11-2010, 08:02 AM | #10 |
lol one last question. What did you guys have to modify on the STRC tray? I'm assuming you're using the stock axial upper links, with rod ends on them? Thanks again! |
02-11-2010, 04:16 PM | #11 |
02-11-2010, 07:02 PM | #12 | |
Had to clearance the tray for the servo horn..I just use the Axial one as a template...If you don"t the horn makes contact not letting you have full steering..the upper links are not stock..we are using a CDW chassis so the uppers had to be made longer..and the rod ends are 3 mm Traxxas and the lowers are all 4mm hardware (Revos) with CDW links. Oh this is her Dad..if you need better pics let me know..it works great! | |
02-11-2010, 07:05 PM | #13 | |
The $60.00 is worth it for what you get..high steer knuckles,tie rod,drag link, servo batt tray( we did not use it ) and all hardware for install. | |
02-11-2010, 08:14 PM | #14 | |
Thanks for the response. I'm assuming the STRC plate works for a stock chassis with stock upper links, just with rod ends on them? | |
02-11-2010, 08:14 PM | #15 | |
and where did you get those body mounts? Last edited by YoterTony; 02-11-2010 at 08:19 PM. | |
02-11-2010, 08:21 PM | #16 |
Pebble Pounder Join Date: Dec 2009 Location: oregon
how much did you have to trim the strc plate
02-11-2010, 08:23 PM | #17 |
Quarry Creeper Join Date: Nov 2009 Location: East Bay
02-11-2010, 08:38 PM | #18 |
| Not to much...It is the area in front of the servo where the horn sweeps when steering( about 1/8")...I will try and get a pick up of the Axial tray and my modded STRC one so you can see what I did.. |
02-12-2010, 06:22 AM | #19 |
Thanks a million for the help |
02-12-2010, 06:22 AM | #20 |
you could always use the axial plate to use as a template to trace where to cut, just my 2 cents
