Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX-10 Scorpion
Thread: Help me choose a set of shocks
Old 03-15-2010, 01:48 AM   #1
Default Help me choose a set of shocks
Hi, I am having trouble working out what shocks I should purchase?
I am buying through www.amainshobbies.com as there postage costs are pretty good as I am in New Zealand (next to Australia) but happy to try other dealers out.
I have a RTR AX10 that I am kitting out.
Also in the meantime I want to refill the stock shocks with some new oil. Any recommendations on what type to use?
Thanks in advance for your help.
Buck.
Bucktallica is offline   Reply With Quote
Old 03-15-2010, 05:05 AM   #2
www.junfac.com
i have http://www.junfac.com/shop/index.php...000c9185d287e2 on my scaler and they perform outstanding
going to buy the transition droop shocks for my crawler project
and the shipping isnt very expensive to Norway so prolly not too expensive to New Zealand either:p
Sverref is offline   Reply With Quote
Old 03-15-2010, 07:27 AM   #3
A lot of people run the Losi crawler shocks.
See65 is offline   Reply With Quote
Old 03-15-2010, 11:23 PM   #4
Originally Posted by Sverref View Post
www.junfac.com
Man I really like the ones you have for your scaler, can they be used on a AX10 crawler too????
Old 03-16-2010, 12:36 AM   #5
yea why not they are really nice shocks, if they are long enough for you then it will be a good replacement for the ax10
Old 03-16-2010, 12:42 AM   #6
Get losi crawler shocks with white springs. I have a set on my shafty for while and it flat-out works!
metallocide is offline   Reply With Quote
Old 03-16-2010, 06:07 PM   #7
Are these the 4" shocks? Do you happen to know the part# for those?
davosfam is offline   Reply With Quote
Old 03-16-2010, 07:13 PM   #8
I'm running the new dual spring RC4WD shocks. You can run these with just a drop of oil and they work awesome. The biggest plus is the are a pretty narrow shock and won't interfere with any steering radius changes you might choose to make.
On the front I'm running the stock black (firm) spring on the bottom and some softer Orange springs from mini-LST shocks on the top.
On the back I am running both the stock firm black springs on the top and the bottom to help with the torque twist.
ElRanoLoco is offline   Reply With Quote
Old 03-16-2010, 09:36 PM   #9
Yes, its 4" shocks. You can buy the whole kit from our vendors:
http://www.rpphobby.com/product_p/losa5082.htm
http://www.tcscrawlers.com/Team-Losi...2-p-16932.html
OR
http://www.horizonhobby.com/Products...rodID=LOSA5082 Avail late April
Old 03-16-2010, 09:44 PM   #10
The part # for the white springs is: LOSA5147
Old 03-16-2010, 10:53 PM   #11
get traxxas big bores, I have losis and they leak like sieves, my traxxas' never have, heres the link:
http://www3.towerhobbies.com/cgi-bin...&I=LXJG90&P=SM
the white losi springs will work well with these however
happy crawling
nismotuningrocks is offline   Reply With Quote
Old 03-16-2010, 11:07 PM   #12
Thanks Ever have problems with them leaking?
Old 03-17-2010, 12:30 AM   #13
Nope. Used teflon tape and leaking became obsolete.
