03-17-2010, 05:48 PM | #1 |
Quarry Creeper Join Date: Jan 2010 Location: Gill, Taxachusetts
| Splitting a battery pack
Where is the best place to find info on splitting a 6cell stick pack?
03-17-2010, 05:59 PM | #2 |
Newbie Join Date: Feb 2010 Location: grand junction
google images... or youtube.. i dont know if you already looked on them but yea
03-17-2010, 06:30 PM | #3 |
RCC Addict Join Date: Oct 2008 Location: PA
It's pretty easy. Once you split it open and look at everything it's pretty self explanatory. Just make sure all of you connections are positive to negative |
03-17-2010, 06:46 PM | #4 |
| I imagine I can purchase some bars, reconfigure the cells, solder them together and shrink wrap. I wonder if I could leave the leads on the final cell from the original stick pack?
03-17-2010, 07:04 PM | #5 | |
Then I went LiPo, best thing I've ever done lol | |
03-17-2010, 07:19 PM | #6 |
| YEah, I need to upgrade the electronics before that happens. In my other thread, I have made a battery tray to fit my stick pack that requires a total rearranging of my ax10.
03-17-2010, 07:23 PM | #7 |
I saw it. The 2 I split up where the same type. They JUST clear as saddle packs (with the factory servo location), so you'll be golden I also used 2 screws/washers in the holes on the axle so I could use the Axial velcro straps. |
03-17-2010, 07:26 PM | #8 |
| Well, I guess I need to dive in and take a shot with building my batteries.
03-17-2010, 07:33 PM | #9 |
Good luck Post up if you have any issues |
03-17-2010, 08:09 PM | #10 |
03-18-2010, 02:37 AM | #11 |
Pebble Pounder Join Date: Sep 2008 Location: New Zealand
I'll jump in with possibily less than 2c worth here. I have done a LOT of pack splitting in the past with my FE boats and a few prototype crawlers. Once you get into pack splitting and building saddles packs etc it is easy and near addictive. A good iron is the key. I now have very little interest in Ni cells as lipo is my friend. FE boats need lipo and Crawlers like them. My basher-buggy is up next and then my Tx handsets will be the last to go lipo. Splitting Ni packs is easy and kind of fun but running lipos is way more fun. |
03-18-2010, 04:08 AM | #12 | |
Quarry Creeper Join Date: Nov 2009 Location: gilbert az
building battery packs. battery pack on axle. how? Jake | |
03-18-2010, 07:47 PM | #13 |
My battery pack is Chinese and the bars will not un-solder. I just put it back together and I'll order one. What is a 2/3a? What is the max mah that I can use foe a stock esc? I keep seeing 1500mah listed for the ax10, but I am using 3300mah? Do I need Dean's connectors? or can I use the basic style plug (Tamiya?)? Thoughts? |
03-18-2010, 08:20 PM | #14 | |
Pebble Pounder Join Date: Jan 2009 Location: At the workbench
2/3a is a smaller cell, yours are sub c The reason for the 1500 maH battery is because of size, 1500 seems to be just about perfect for shoehorning into a crawler. | |
03-18-2010, 08:27 PM | #15 | |
trying to figure my best option. | |
03-18-2010, 09:01 PM | #16 | |
You can get a lipo cut-off from novak. They come set up for 2s or for 3s. And don't forget a lipo charger. | |
03-18-2010, 09:12 PM | #17 | |
03-19-2010, 06:48 PM | #18 |
| Pictures of my 1st failed attempt |
03-20-2010, 06:27 AM | #19 |
Just pull on those tabs, they pull right off
03-20-2010, 03:52 PM | #20 |
