03-27-2010, 10:41 AM | #21 |
Pebble Pounder Join Date: Jan 2010 Location: Murrieta
under drive in the rear is were it sounds like it works the best.. So much info this is great thanks for the help ( and this is not even my post )
03-27-2010, 03:00 PM | #22 | |
Quarry Creeper Join Date: Jan 2010 Location: Gill, Taxachusetts
03-27-2010, 07:39 PM | #23 |
Pebble Pounder Join Date: Sep 2009 Location: Abbotsford, B.C., Canada
Anybody have a part# for the underdrive set?
03-27-2010, 08:22 PM | #24 |
Quarry Creeper Join Date: Oct 2006 Location: where fear and common sense don't get in the way
03-27-2010, 09:21 PM | #25 |
03-28-2010, 11:46 AM | #26 |
03-28-2010, 11:56 AM | #27 |
Quarry Creeper Join Date: Sep 2008 Location: Oakley
I run the standard HD gears in the front and the underdrive in the rear. It helps with the TT and makes it a little easier to tune the TT out more using link placement, etc. I've seen some scalers that have OD front and UD rear. They didn't seem to do too bad. I wouldn't like to see what happens if you get it bound up really bad though. |
04-01-2010, 09:12 PM | #28 |
Rock Crawler Join Date: May 2009 Location: Idaho Falls, ID.
got my rear gears today can't wait to put them in and try it out will post up after with results
04-02-2010, 01:45 AM | #29 |
Rock Crawler Join Date: Dec 2009 Location: Lynnwood
jsut got my order from rpp and put the 43/13 gears in the rear, and vp knucks for my bta, with a little testing its hard to notice a difference, ppl say it helps with steering but it hard for me to tell at this point since i did the new knuckles too cant wait to take it to the homebrew course at the buddies house and do some real testing
04-02-2010, 05:52 AM | #30 |
Newbie Join Date: Jan 2010 Location: lamoine
A couple in our club installed the under drive in the rear. Love it! Good luck Last edited by 98zj5.9; 04-02-2010 at 05:53 AM. Reason: Spelling |
04-02-2010, 07:04 AM | #31 |
I have the 43\13 in the rear of mine. There is a noticeable torque twist difference. I am very happy with how it drives with this setup.
04-02-2010, 08:41 AM | #32 |
Quarry Creeper Join Date: Sep 2009 Location: west sacramento
04-02-2010, 09:50 AM | #33 |
Newbie Join Date: Sep 2009 Location: Grand Junction
I have a 9lb scale rig with rs pro 21.5 and plastic gears in the trans, I have the od front ud rear, it helps with all control. the truck did not want to go straight, had tqt. The gears helped alot. I also have the od/ud in my comp crawler, with very little wieght in the rear, same motor esc as scaler,vp dig, it has been bound up sevral times (plastic gears in trans), I have no problems so far. I have another crawler with the ud only, it does not work as well as my comp rig in turning or climbing. As far as reverse I have not noticed any problems (reverse adds points). I hope I've helped.
04-03-2010, 10:01 AM | #34 |
Quarry Creeper Join Date: Aug 2009 Location: Philadelphia, PA
So there is no answer on which one to get, if you could only get one. I wanted to get the under drive but not yet. What prices have you guys seen it for? Here a cheap link to over drives. http://cgi.ebay.com/Axial-AX30401-AX...item4a9f03cbd7 |
04-03-2010, 10:25 PM | #35 |
04-03-2010, 10:53 PM | #36 | |
Quarry Creeper Join Date: Feb 2008 Location: Albany
Thanks for in the info, This thread made me go out and try it. I like it much better now! | |
04-04-2010, 06:33 AM | #37 |
RCC Addict Join Date: Apr 2008 Location: Georgia
[QUOTE=skywker51;2391474]I havent had an issue with mine yet, Im runnin the 43/13 in front, stock in back. I thought the 36/14 was for the front, and the 43/13 is for the rear axle. I assume you have undrive for your front axle. |
04-04-2010, 08:34 AM | #38 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
| http://www.rpphobby.com/product_p/ax30401.htm The lower gear range set reduces torque twist (43/13) (Rear 3.31) The higher gear range offers higher top speed (36/14) (Front 2.57) Use the gears in different combinations front and rear to reduce torque twist in the rear and overdrive the front axle to help pull you through climbs easier 4 Last edited by JesterSpec; 04-05-2010 at 06:37 AM. |
04-04-2010, 10:47 AM | #39 |
just put my underdrive gears in last night there quite and very cool love the climbing and turning I'd say nice add on!
04-04-2010, 10:49 AM | #40 |
[QUOTE=salmonfacesalad;2391699] thats diffrent how's the underdrive in the front work?
