03-26-2010, 07:01 PM | #1 |
Quarry Creeper Join Date: Jan 2010 Location: Gill, Taxachusetts
| Underdrive in the rear differential
Is the purpose of underdrive gears to be "pulled by the front as to not induce a back flip and keep the front wheels planted? |
03-26-2010, 07:07 PM | #2 |
Quarry Creeper Join Date: Oct 2009 Location: Indianapolis, IN
That was my understanding. I saw a small difference when I installed mine but not enough to make much of a difference. I'm waiting for a set of overdrive gears to put in the front now to see how that works.
03-26-2010, 07:24 PM | #3 |
that and to trun a little tighter
03-26-2010, 07:50 PM | #4 |
Rock Crawler Join Date: Dec 2009 Location: Lynnwood
i heard it helps out with TT a little mine are on the way
03-26-2010, 07:54 PM | #5 |
It certainly helps with torque twist, all of the other things mentions are additional benefits too.
03-26-2010, 08:18 PM | #6 |
I have tried it both ways overdrive and underdrive and it works about the same either way tighter turns it keeps the rear tires slightly slower than the front and improves the front traction as far as TT it helps but won't eliminate it. I prefer the underdrive set up as it produces most wheel speed.
03-26-2010, 08:31 PM | #7 |
Rock Crawler Join Date: May 2009 Location: Idaho Falls, ID.
so underdrive in rear and overdrive in the front should be the best? or is it one or the other?
03-26-2010, 08:32 PM | #8 | |
03-26-2010, 08:41 PM | #9 |
Pebble Pounder Join Date: Jan 2010 Location: Murrieta
was planning on doing mine as well would like to know wich setup has helped the most with tt thanks,,,
03-26-2010, 08:58 PM | #10 | ||
It's works good either way I've already explained my set up above it's a matter of personal preference. | ||
03-26-2010, 09:34 PM | #11 |
Thanks for your repley... i try mine in rear see how i like it...
03-26-2010, 09:45 PM | #12 |
I'm tring the rear also thanks for the info
03-26-2010, 09:53 PM | #13 |
Quarry Creeper Join Date: May 2008 Location: Grande Prairie, Alberta, Canada
I have 2 trucks, one Overdrive in the front and the other Underdrive in the rear. The underdriven truck is much faster now but both work great. I don't really see the benefit of putting both in your truck. One of the guys here has both sets in his truck but it holds nothing over mine. The overall outcome by putting one OR the other in is about the same.
03-27-2010, 06:57 AM | #14 | |
I could use some expertise here. | |
03-27-2010, 07:29 AM | #15 |
N.E.R.C.C Uncle Blinky Join Date: Dec 2008 Location: RUKDNME...
i run od up front and hd in the rear. i tried od/ud f/r and found it uber ruff on the tranz. GSRCC Drail
03-27-2010, 07:34 AM | #16 |
That might be a worry i have in the back of my head the trany... Has anyone running this setup ever ran into a trany problem?
03-27-2010, 07:46 AM | #17 |
Rock Crawler Join Date: Aug 2008 Location: B.C.Canada
i started with the rears and i ran both in a heavy rig last year and it creates alot of stress and binds to much but i never broke the trany,it had alum.gears and H.D outputs so that may have helped i pulled the rears i ended up just running the fronts,i like the faster front axle speed and it turns tighter then just the rears it seems |
03-27-2010, 08:15 AM | #18 |
Rock Crawler Join Date: Jan 2010 Location: SOUTH CRAWLINA
I'm actually going here in a few minutes to see how the overdrive front and underdrive rear works. I will post my findings later today. |
03-27-2010, 08:29 AM | #19 | |
03-27-2010, 08:43 AM | #20 |
Rock Crawler Join Date: Jan 2010 Location: Arvada
the only benefit from both overdrive in front and underdrive in rear is for turning in my opinion. i've seen a rig perform with it on and it's almost like dig. but I think it's too much, he also had a hard time with reversing. I have the under drive in the rear and I love it. I think it's all you need |
