04-11-2010, 08:01 PM | #1 |
RCC Addict Join Date: Jan 2010 Location: Dallas
| I know... Slipper clutch again!!
I know all of us have gone over and over about the slipper, but I am having trouble and did quite a bit of reading and searching. I found a lot of ideas as to run or not run the slipper. I do want to keep mine, but I am not if its going to take dump in the slightest of challenges. is there a way to either score the slipper plates, and or do something to take away the wimpyness of the slipper and still keep it?
04-11-2010, 08:19 PM | #2 |
Either crank it down as tight as you can or ditch it. Its really not catastrophic as it sounds to run without one.
04-11-2010, 08:30 PM | #3 |
Pebble Pounder Join Date: Feb 2010 Location: Calgary
The ARTR doesn't come with one. If it's causing you grief, get rid of it. You just have to watch out and take your finger off the go trigger if it starts to get bound up too tight.
04-11-2010, 08:35 PM | #4 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
I don't run a slipper and no real "broken parts due to binding" to report If you just use common sense, it should be fine, we all know if all the tires are bound up the car isn't going anywhere and its going to cause problems... |
04-11-2010, 09:06 PM | #5 |
My truck was a kit and did not come with a slipper. I run a Rooster with 45T at 8.4V (ran a 65T as well), the only breakage I normally have are drive shafts (Traxxas), but it is pretty rare. I've seen the peeps that have slippers have to take a repositions because they got into a tight spot and their slipper kept them from getting out of it.
04-12-2010, 08:42 AM | #6 |
Pebble Pounder Join Date: Jan 2010 Location: Murrieta
I kept mine just tighten all the way ... never had a problem sence... Real easy fix...
04-12-2010, 10:50 AM | #7 |
04-12-2010, 11:20 AM | #8 |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
04-12-2010, 11:53 AM | #9 |
Quarry Creeper Join Date: Nov 2009 Location: East Bay
| I have been running the slash slipper set up on my kids and it has worked great..the stock one always seemed to fail. |
04-12-2010, 01:49 PM | #10 |
04-12-2010, 02:20 PM | #11 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
best way ive found out to set up a slipper is to hold the rear wheel in place on the ground. have the slipper tight enough so it will pick up the front with the throttle. when the truck hits your arm and the truck is in a bind the slipper starts slipping. make sure it will lift the front with full throttle stabs too. but honestly like everyone has said. just crank it down tight. |
04-12-2010, 02:42 PM | #12 |
| Sure, Just tighten the heck out of it.
I am not so much married to the slipper it is just simply there now but it is failing mostly since I put on some rovers. It appears that it is worn or semething is allowing it to slip to easily. I am thinking of a little drop of loctite between the slipper plates and a better tightening tool!! My wrench that came with my frog just aint cutting it!
04-12-2010, 04:54 PM | #13 |
RCC Addict Join Date: Oct 2008 Location: PA
I accidentally got some WD-40 on my Slash's slipper clutch and it slipped like you wouldn't believe. I took it apart and cleaned it all up with some Awesome Cleaner (same as Simple Green), works perfect again That being said, I've never had a problem with Axial's, so maybe something made it's way in or a little assembly grease got on the contact surface while it was being assembled, hell, maybe even finger oil. |
04-15-2010, 02:04 AM | #14 |
Newbie Join Date: Apr 2010 Location: British Columbia
has anyone here ever had a problem with the stock axial transmission spinning out the middle gear? my buddy and i keep killing them like crazy stupid plastic! anyone know of any metal replacements?!?!
04-15-2010, 02:57 AM | #15 | |
Quarry Creeper Join Date: Nov 2009 Location: gilbert az
Jake | |
04-15-2010, 08:06 AM | #16 |
Quarry Creeper Join Date: Nov 2007 Location: NH
You have three choices that I can see 1) ditch the slipper 2) run a slash slipper (which I'm currently doing one one of my rigs) 3) put a few drops of super glue on the slipper pads before assembly |
04-15-2010, 09:16 AM | #17 |
Newbie Join Date: Jul 2009 Location: SANTEE
when you take it apart...take a nail file and sand the pads and the metal parts on the pad...should grab better without locking the system up
04-15-2010, 10:30 AM | #18 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
The slipper clutch is your friend. Thats what so many RC's use them. Can you run a RC with out one sure you can but you are taking a chance you will break parts with out one. I have a slipper in all of my RC's and very rarely have had it slip unless it was in a bind and that is when you want it to slip. Would you rather have it slip in a bind during a comp or break something in your tranny?
04-15-2010, 11:42 AM | #19 | |
04-15-2010, 11:49 AM | #20 |
RCC Addict Join Date: Mar 2010 Location: Alburtis
I did a bone head noob move when I first installed mine. Totally missed that step about removing the plastic. I think they should make that step much bolder! Anyway, I was slipping all the time with the plastic on. Once I peeled the plastic and stuck it to the plate, as directed, the slipper started working flawlessly. Every once and a while it slips. Usually only when my tire is completely bound up. I am sure I have paid for it many times over by now. Set up properly they seem to work great. Wes |
