Thread: ax 10 4wheel steering help
Old 11-08-2010, 09:43 PM   #1
Default ax 10 4wheel steering help
I want to put 4ws on an ax10, ive ordered the kit and servo...what radio/reciever should i use to get all fuctionallity out of it such as independant controll for front/rear, crabwalk etc. DO i need anything else? My first crawler build so any help is appreciated
york1974 is offline   Reply With Quote
Old 11-08-2010, 09:53 PM   #2
Tossin' Salad
First, read this thread.
Frogger's BAD COP twin!
Now, in short, here is what I used.
Spektrum DX3R radio
Spektrum SR300 RX
PunkRC 4 steer switch
dual HS-7954SH servos
Castle Creations BEC
HH Torquemaster BR-XL ESC
HH Torquemaster 45T handwound motor
That will get you started. The PunkRC 4 steer switch is badass! I use a 3 position button on the TX to switch between different modes on the 4 steer switch. Mode 1 = 4 wheel steer. Mode 2 = 2 wheel steer. Mode 3 = crab walk.
Have fun.
Casey
KC_JoNeS is offline   Reply With Quote
Old 11-08-2010, 10:21 PM   #3
thanks for the suggestions. You rock
Old 11-08-2010, 10:27 PM   #4
Tossin' Salad
Keep in mind, this setup with 4 wheel steer will not be allowed to compete in any class...except, if you keep your 4 steer switch locked at 2 wheel steer mode. Then you can compete in the sportsman class. But, I did not build this to compete with...just for fun...and it is fun!
Casey
Old 11-09-2010, 07:53 PM   #5
I am not sure about this, because I have never built a rig with 4w steering. I wanted to build a comp rig, but I am pretty sure you can get a Futaba 3PM-X and your done. It has 4w steer mixing.
Aggie01 is offline   Reply With Quote
Old 11-09-2010, 07:56 PM   #6
Tossin' Salad
This is correct...and cheaper. With the 3PM-X, you will not need the PunkRC 4 steer switch.
I was meerly showing my setup.
Casey
