04-24-2012, 07:47 PM | #241 |
| Re: zee Retour Rapide Deux
Definitely a nice piece. I got lucky enough to get a pre-production piece in my gubby paws. |
04-24-2012, 07:49 PM | #242 |
| Re: zee Retour Rapide Deux |
04-30-2012, 06:37 PM | #243 |
Went out to the garage to do some cleaning, said screw that, and proceeded to make an even bigger mess. Grabbed a chunk of delrin, stuck my endmill in the drill press, and when I was done I had this. Weighing in at a scant 6 grams, its 3 grams lighter than the original. Last edited by Duuuuuuuude; 04-30-2012 at 06:41 PM. |
04-30-2012, 06:47 PM | #244 |
On a more serious note, CHUD sent me a b-day present without even knowing it. Friday morning I found some new UGC goodness in my mailbox. He sent me some lightweight FBII chassis panels in my favorite color. The originals... The lightweight version... And while I had it apart, I put my skid on a diet too. I forgot to weigh it before though...but I think its down a quarter ounce or so. |
04-30-2012, 08:01 PM | #245 |
Nobody Join Date: Sep 2008 Location: Maine
Bitchin. What's the lightest sportsman rig these days?
04-30-2012, 08:11 PM | #246 |
| Re: zee Retour Rapide Deux Dunno, it isn't mine. I'm still a bit over 5 lbs, though I'm not on a serious hunt for weight reduction. Also, the delrin d-mount is stronger than it looks. Bolted it on and ran a pack and it did just fine. This might actually be something to pursue.... |
04-30-2012, 08:42 PM | #247 |
All of your work looks really good. Just a solid rig man |
05-01-2012, 10:02 AM | #248 |
So where's the pics with everything mounted?!?
05-01-2012, 10:38 AM | #249 |
| Re: zee Retour Rapide Deux Thank you sir. Not too bad for an old hack. Here's the new chassis plates. Thank you Juan. Here's how the delrin mount started its life...Yes, I'm still hand feeding parts into an endmill chucked up in a drill press. And here it is installed. |
05-01-2012, 10:43 AM | #250 |
Me want delrin piece too.
05-01-2012, 10:44 AM | #251 |
I really want that rear tray |
05-01-2012, 10:46 AM | #252 |
| Re: zee Retour Rapide Deux I figured you would...Ashton too. Talked to Dan last night on the tely-fone and told him what I did. Delrin may be an option for these. Got some testing to do though. Also, I gave him all the feedback from my testers. The new run of mounts will be thinner, lighter, shorter, and not have the bevel on the rear edge of the uprights. He's also going to round off the pointy corner up top. Last edited by Duuuuuuuude; 05-01-2012 at 10:53 AM. |
05-01-2012, 10:50 AM | #253 |
06-02-2012, 07:45 PM | #254 |
So its kind of a bittersweet day. zee Retour Rapide Deux is no longer mine. However, I have raised about half the cash I need for my mill. I just got some new stickers too. Last edited by Duuuuuuuude; 06-02-2012 at 07:50 PM. |
06-02-2012, 08:39 PM | #255 |
Rock Crawler Join Date: Oct 2011 Location: south of nowhere
Wow, sorry, um no happy for you Learned a lot from that build good luck with the mill......even bigger money pits than crawlers, but they can pay for them selves in the long run |
06-02-2012, 09:56 PM | #256 | |
| Re: zee Retour Rapide Deux Quote:
The plan is to have the mill pay for itself and more. We'll see how that works out. | |
08-12-2013, 06:02 PM | #257 | |
Rock Stacker Join Date: Mar 2013 Location: Amsterdam
So... I've browsed the Mayhem Engineering site, no D-Mount to be found. Care to share a link to get some ? | |
08-12-2013, 06:25 PM | #258 |
Check the link in my sig.
08-12-2013, 06:43 PM | #259 |
What is 2.5.5?
08-12-2013, 06:58 PM | #260 |
