01-15-2012, 10:17 PM | #1 |
Pebble Pounder Join Date: Dec 2009 Location: Magalia, CA
| AX10 on wraith axles ...New Brushless motor and GOAT 3s esc!!
This is my ax10 I threw together. Running the ae1 esc- Now runnin the GOAT 3s Wraith axles locked, STRC steering links New wraith spline drive shafts Wraith transmission/ 20t motor- Now running 18.5 t Novak brushless ballistic motor!! HB rovers on XR10 Beadlocks hpi 2.4 ghz. Rx/tx 3ch Hitech ultra torque servo- Now running the as3 digital high torque servo INTEGY BAJA lights ! -Not any more... Now running a common sense 2s 7.4 volt LiPo!! Let me know what y'all think of er! Last edited by RCRockstar; 05-21-2012 at 08:39 PM. |
01-15-2012, 10:31 PM | #2 |
| Re: AX10 on wraith axles ...Baja status!
just put these on today!! Made by Integy, Won em off ebay for $24 shipped. All alluminum, pretty stout and bright!
01-16-2012, 06:50 AM | #3 |
Looks fun. How wide is it with the axles and those wheels you have on there?
01-16-2012, 11:02 AM | #4 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
^^ you need axle wideners to run those wheels or they rub on everything.. a friend has them on the stock ax10 axles and is running 15mm widerners front and rear. oh and rig looks better than i thought it would!!! how does it perform on the rocks?? |
01-16-2012, 08:16 PM | #5 |
Its more of a ripper than a Crawler. Its performs well but it hauls ass and is a lil top heavy. I will post some pics of my crawler.
01-16-2012, 09:03 PM | #6 |
O and its 11 ¾" outside of tire - outside of tire
01-16-2012, 09:15 PM | #7 |
Heres my crawler.. in a nutshell ae2 esc Tekin 55t spektrum rx/tx sticky compound ripsaws castle bec warthog chassis rear steer ax10 axles/transmission Last edited by RCRockstar; 01-16-2012 at 09:18 PM. |
01-17-2012, 08:42 AM | #8 |
Rock Crawler Join Date: Nov 2010 Location: Ohio
I have been thinking about trying the OCP axles, but I'm hesitant to dump money into a set for them to be worthless on a Comp rig. I was thinking of using the XR wheels also to keep the width from being to wide. How does it perfom? How well does the tranny fit? I already have a Wraith tranny OTW, hoping to use the DIG once available, to replace the heavy DNA unit I'm using now.
01-17-2012, 07:11 PM | #9 |
Everything performs awesome! Fitment is perfect. All the wraith parts are badass imp.
01-19-2012, 10:49 AM | #10 |
Rock Stacker Join Date: Aug 2005 Location: Dallas
11 and 3/4 " wide is very wide for a 2.2 rock crawler. That's still falls inside the legal requirements, but as soon as you comp that rig it's going to feel like you are wheeling in a 1.9 course.
01-20-2012, 11:17 AM | #11 |
Yea this isnt my comp rig. The tube chassis rig would be the one id comp with. The wraith axles are pretty wide but keep it stable, and one day i might go brushless with it for more speed so stability was more my issue when building it.
01-20-2012, 06:18 PM | #12 |
With the XR wheels it is only 1/2" wider than stock AX wheel/axle combo right?
01-21-2012, 12:16 PM | #13 |
My ax10 with the warthog chassis and ax10 axles/wheels is only 10" from outside of tire - outside of tire. That makes it 7/8s" less on each side. wraith axles with xr10 rims = 11 3/4"
01-21-2012, 02:48 PM | #14 |
Ah, that would make it 1.5" wider overall for me. My current width is 10.25".
01-22-2012, 04:15 PM | #15 |
I swapped over From the rovers to the axial ripsaws. I love em and they shaved a lil width off my crawler.
01-26-2012, 12:57 PM | #16 |
| Re: AX10 on wraith axles ...Snow run!!
Just bought a new skid plate to fit my new r2 tranny for my warthog! I will post some pics once i get the goods.
02-05-2012, 03:18 PM | #17 |
So I just added the r2 tranny & greesed it. Is it supposed to be kind of a louder tranny than a stock axial? Im getting a whinning noise from mine and not sure why.. I greesed the gears pretty good.. maybe my pinion gear is too tight???
02-06-2012, 11:12 AM | #18 |
Newbie Join Date: Jan 2012 Location: halifax
So ripsaw vs HB rovers? What do you like better? Why? Thank you.
02-07-2012, 10:22 PM | #19 |
The ripsaws seem to hook up better for crawling .. I do like the rovers but the side walls seem too flimsy.
02-08-2012, 05:59 PM | #20 |
Quarry Creeper Join Date: Aug 2011 Location: not south enough
Good idea, I am not a fan of my Wriath at all, and I just bought an ax-10 because I was sick of saying I have never tried one when I was in a Crawler king ax-10 comparison thread, butI am not a fan of the ax-10 either, I am done buying Axial stuff, but I may just need to frankenstein them together to get a rig that is actually worth using over my 100 times more fun modded Crawler Kings.
AX10 on wraith axles ...New Brushless motor and GOAT 3s esc!! - Similar Threads | ||||
What parts interchange between Ax10/scx10 axles and wraith | Full Penetration Fab. | Axial Wraith | 9 | 01-02-2017 06:47 PM |
difference between ax10 and wraith axles | phre0n | Axial Wraith | 7 | 11-20-2011 01:30 PM |
