02-05-2012, 03:52 PM | #1 |
Rock Stacker Join Date: Jan 2012 Location: Kingsport
| AX10 Driveshaft question
I've been having issues with my rear driveshaft coming off the transmission shaft. The set screw is not backing out because i can look down inside the shaft when it slips off and i can still see the tip of the screw poking out. I have used locktight on the set screw. I noticed the yoke has two holes for set screws, would it help to put two set screws in it? Any suggestions? |
02-05-2012, 03:59 PM | #2 |
Rock Crawler Join Date: Jan 2007 Location: West Seneca
| Re: AX10 Driveshaft question
Yep either a set screw in each side or what i do is cut down a button head screw so it just sticks out a bit and crank down gives you more than a little set screw can take with out stripping
02-05-2012, 03:59 PM | #3 |
Quarry Creeper Join Date: Jan 2012 Location: okanagan BC
2 is twice as good as one, havnt had this problem, but that makes sense, or drill through the output? pin it all the way through
02-05-2012, 04:20 PM | #4 |
| Re: AX10 Driveshaft question |
02-06-2012, 11:01 AM | #5 |
Newbie Join Date: Jan 2012 Location: halifax
2 screws will keep it nice and tight...I use cap head screws when I have them, that way I can use vise grips to get them out if they strip out the hex. No loctite for me!!!! Good luck
02-06-2012, 11:15 AM | #6 |
02-06-2012, 11:41 AM | #7 |
Rock Crawler Join Date: Nov 2009 Location: poteau
i'll agree with that, i didn't know the stock outputs were hollow! i snapped one the other day, replaced it with robinson racing one piece.
AX10 Driveshaft question - Similar Threads | ||||
ax10 driveshaft | LS1Armyboy | Axial AX-10 Scorpion | 4 | 07-22-2010 12:46 PM |
Which aftermarket driveshaft for AX10? | chvy4wd | Axial AX-10 Scorpion | 56 | 12-30-2008 10:52 AM |
AX10 driveshaft. | Oze30 | Newbie General | 13 | 02-28-2008 09:52 PM |
AX10 Driveshaft Failure | ElectronJunk | Axial AX-10 Scorpion | 92 | 01-14-2008 09:34 PM |
ax10 driveshaft assembly? | mtnyote | Axial AX-10 Scorpion | 18 | 12-26-2007 01:23 AM |
