04-20-2012, 10:47 PM | #1 |
Rock Stacker Join Date: Mar 2012 Location: lakewood
| Driveshafts??
what driveshafts wouldyou guys suggest
04-20-2012, 11:39 PM | #2 |
Newbie Join Date: Nov 2011 Location: Imperial
| Re: Driveshafts??
Mip Cvd, jun fac or axial wild boar.
04-20-2012, 11:47 PM | #3 |
Quarry Creeper Join Date: Aug 2011 Location: Australia
| Re: Driveshafts??
Im sure you will get lots of comments for MIPs (probly some flamming too). Ive never tried MIPs but I run traxxas shafts with metal rings around the yokes and the hold up to Holmes Hobbies 35t plus they are light and cheap. Steer clear of Intergy (also known as interjunk) Nik |
04-21-2012, 04:04 AM | #4 |
Pebble Pounder Join Date: Feb 2011 Location: Grand Rapids, Mi.
| Re: Driveshafts??
I have MIPs on my AX10 and have not had one single issue with them, and I do not treat it on the easy side, it is being pushed with a 27t with 20 tooth and 80 tooth gears everything else is stock, she sure gets treated rough.
04-21-2012, 07:17 AM | #5 |
Newbie Join Date: Apr 2012 Location: NWA
| Re: Driveshafts??
I have the integy shafts and have never had a problem in three years with them..
04-21-2012, 07:29 AM | #6 |
| Re: Driveshafts??
If your not breaking Integy shafts then this means two things. One, your the first. Two, you must not be very hard on equipment. The traxxas shafts are cheap if you already have the steel outdrives to go with them, but if you gotta buy it all then you may as well buck up for the MIP's. I'm slowly converting my fleet over to them as I can afford it. Their only downside is they are the heaviest driveshaft on the market, but the heft brings the beef. I've run the Revo joints made easy for a while and they hold up decent enough, but they rob to much clearance on the 1.9 trucks. Eventually the plastic output yokes will twist and egg out enough to loose the U-joint, but it takes longer than with the smaller Traxxas shafts. I ran the Junfacs for a while. The holes for the cross pins got ovaled out and split eventualy. I broke two pins in two years, not bad. Covering the pins in two layers of heatshrink is a must, otherwise you'll be looking for those pins on the rocks. Their major flaw is that the slip spline is a D shape that binds very badly when under torque making for quirky suspension action. It's also very hard on the axle's pinion and trans output bearings. |
04-21-2012, 07:48 AM | #7 |
Pebble Pounder Join Date: Mar 2011 Location: St. Louis
| Re: Driveshafts??
MIP all they way. I have had 0 issues for years and I treat them very badly. Rebuild kits are cheap. Eventually the holes oval out but a drill press is all you need to make a new set of holes.
04-21-2012, 08:14 AM | #8 |
| Re: Driveshafts??
thanks guys i think im going to go with the jun fac shafts
04-21-2012, 09:15 AM | #9 |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
| Re: Driveshafts??
MIP are the winner,very good made,and they take allot of beat |
04-21-2012, 09:23 AM | #10 |
Quarry Creeper Join Date: Jan 2012 Location: okanagan BC
| Re: Driveshafts??
again for the MIP, the only issue i had is not really a problem, but, if you change to add a dig unit, if you shorten the rear shaft, watch the splines, they dont go full way.......very annoying, these shafts would be better with full length splines of course then again you could just order the dig shaft ...... |
04-21-2012, 10:18 AM | #11 |
Another here with mips. Only problem I've had was snapping crosspins. Drill bit shanks seem to hold up better as replacements. 3s&4s sensored brushless.
04-21-2012, 11:23 AM | #12 |
| Re: Driveshafts??
Maxx!
04-21-2012, 12:53 PM | #13 |
| Re: Driveshafts??
ok were can i find the mip's for fairly cheap
04-22-2012, 07:17 PM | #14 |
| Re: Driveshafts??
I think rc4wd.com has for $50.00...... Unless u find a used pair.....that's ur best bet
04-22-2012, 08:42 PM | #15 |
Quarry Creeper Join Date: Jul 2008 Location: South Dakota
| Re: Driveshafts??
I'm still using my stock kit shafts from 4 years ago. I'm probably due to upgrade.
04-22-2012, 08:44 PM | #16 |
| Re: Driveshafts?? |
04-22-2012, 11:27 PM | #17 |
Quarry Creeper Join Date: Sep 2010 Location: Perth Australia
| Re: Driveshafts??
I run MIP's very happy with em...
04-22-2012, 11:57 PM | #18 |
| Re: Driveshafts??
Once you get the mip's, you will never look back |
04-23-2012, 11:43 AM | #19 |
Rock Crawler Join Date: Dec 2009 Location: Beaumont, Tx
| Re: Driveshafts??
I would go with MIP's they are beef! I just got some for half price at TCS for $34.00 I also had Janfac's and they are ok, but the MIP are way better in everyway.
04-23-2012, 12:25 PM | #20 |
| Re: Driveshafts?? here are the to options,one dedicated to dig unit,one withou dig unit Axial AX10 Scorpion C-Drive Splines (2pcs) by MIP | eBay Axial AX10 Scorpion MIP C-Drive Splines (2pcs) for DIG | eBay go for it,for me MIP rulz! |
Driveshafts?? - Similar Threads | ||||
best driveshafts? | black92coupe | Losi Mini-Rock Crawler | 34 | 06-16-2010 12:42 AM |
need some driveshafts for an R2 | gobucks | Newbie General | 2 | 04-15-2008 10:38 PM |
which driveshafts? | all hung up | Newbie General | 3 | 04-11-2008 06:22 AM |
