02-07-2010, 10:17 PM | #1 |
Rock Stacker Join Date: Jan 2010 Location: Canada
| best driveshafts?
the pins in the "u joints" in my set of plastic driveshafts fell out so i replaced them with some aluminum ones made by 3 racing(the only thing my lhs had). and now i broke both the front and rear driveshafts at those same pins, this time instead of falling out they just broke.. i cant get the pins out to use a paperclip or something in there so im wondering who makes the best driveshafts, i think ive seen a different type of driveshaft but dont know who makes them my truck is completely stock with some chisels on there, the rears broke when it was kind of in a bind and i tried to gas it out but the front broke trying something really easy that i had done a few times without any issues and really shouldnt have broke.... any help is appreciated |
02-07-2010, 10:27 PM | #2 |
02-07-2010, 10:59 PM | #3 |
i tried searching for a post like that, thank you very much! im taking it these havent failed you yet? |
02-07-2010, 11:00 PM | #4 |
02-07-2010, 11:47 PM | #5 |
I seen most guys use the yokes like your eric. my lhs didnt have any when I was needing em. so I ended up with a stamped shaft with what I think was e revo metal yokes? I'll see if I have a pic. the yoke is all metal. and its overall length is a bit shorter. but they are fat,back fits with no mod at all. but you will want longer grubs. the front at the axle requires no mod. but the front at trand under the spur is to tight. I had to grind the outer perimiter of trhe yoke. but its so fat there no worries. |
02-16-2010, 07:18 PM | #6 | |
| Quote: for anyone thats going to do this, you're gonna end up needing 4 packs of the 1539's to have enough "center balls" (dont know what they're called) but if you replace the 1953 6 pack with traxxas part no. 1951 , you get 2 of each shaft (enough to do front and rear) and 4 of those center balls(also enough to do front and rear), if i knew this in the first place i could have saved myself like $8 lol if anyone is confused, buy 2 packs of 1539's and one 1951 | |
02-16-2010, 09:44 PM | #7 |
Rock Crawler Join Date: Jun 2009 Location: SF
I am a lazy man, so I used a set of MIP shafts, no issues, not super cheap though...
02-16-2010, 11:23 PM | #8 |
Rock Stacker Join Date: Jan 2009 Location: springfield
How do you like those mip's, they look pretty nice.
02-17-2010, 08:40 AM | #9 |
Quarry Creeper Join Date: Mar 2009 Location: mesa
my mongoose ate stock driveshafts until i did the traxxas deal 2#1539 and 1 #1951 not afraid to use the throttle anymore even held up to my three cell tests its the way to go and its cheaper in cost than stock replacements
02-17-2010, 08:56 AM | #10 |
Pebble Pounder Join Date: Dec 2009 Location: England
im a bit lazy to but that traxxas way looks pretty good
02-18-2010, 09:44 AM | #11 |
Rock Stacker Join Date: Feb 2010 Location: St. Joseph
anyone know what the price difference bwtween the MIPS and the traxxas shafts are right off hand?
04-09-2010, 01:03 PM | #12 | |
| Quote: This is an awesome mod. Being a former shafty comp guy I had plenty of Traxxas Stampede shafts and balls. I went to the my lhs and spent $10 for two 1539's and I got this mod done on my lunch break. thanks for sharing this! Last edited by helhedded; 04-09-2010 at 01:12 PM. | |
04-09-2010, 01:15 PM | #13 |
Quarry Creeper Join Date: Dec 2009 Location: Jacksonville, FL
04-09-2010, 01:46 PM | #14 |
RCC Addict Join Date: Mar 2010 Location: Yelm
Can someone post a link to some place where I could buy the Traxxis driveshaft? I have tried to do a search on my computer, but I dont know exactly which one to get, or a place that sells them. Where do you guys usually buy them from???? |
04-09-2010, 02:03 PM | #15 |
Rock Crawler Join Date: Aug 2009 Location: crawlerado springs
the mips are the s**t!!! i was snapping pins left and right... since i got the mips, i havent had a single problem! and they look awesome! you can order them straight from mip for 45$ a pair... theres a guy that found them for 28 bucks for a pair! i dont remember where he found them though! but the mips are tough as hell and you have any regrets if you buy them!!!!!!!!!! |
04-09-2010, 03:02 PM | #16 |
Pebble Pounder Join Date: Jul 2005 Location: Warrington, UK
The MIPs are pricy, especially posted to the UK BUT after building them I wouldnt have anything else not tried them yet but the quality simply oozes from them. Neater than the traxxas mod too.
04-09-2010, 03:19 PM | #17 | |
http://www.tcscrawlers.com/Traxxas-S...1-p-16157.html or you can go into any hobby store that carries traxxas parts. | |
04-09-2010, 03:50 PM | #18 |
04-09-2010, 07:06 PM | #19 | |
04-09-2010, 07:22 PM | #20 |
Pebble Pounder Join Date: Dec 2007 Location: out crawlin thrown rocks at my rig.
i run the mini revo axle shafts that go from the diff to the wheels. sorry dont have the part no#but easy enough to find. buy four axle packs. pretty cheap. trade out yokes, u don't even have to trim or cut the shafts downand they are bullet proof, seriously ps. i drilled a small hole in the pinion shaft for the pin to go all the way thru. |
