05-16-2012, 08:06 AM | #1 |
Pebble Pounder Join Date: Apr 2012 Location: SWE
| need advice, setup on budget 200$
did invest in an used ax10. RtR, almost zero usage, 0 scratches. Alu uppdated, everything but transcase and axels. but still in stock setup. 3link and chassie have read alot about diffrent uppdates, and the wall of text crits my eyes. so many choices. Well for the help part. if you had 200$ to make your ax10 a good/comp crawler What woud you fix first for 200 bucks? (not counting weels/ esc and motor) going Fxr-35T edit , ups forgot tires, dry cracks, hard as rock =) Thanks. Last edited by nitrooxide; 05-16-2012 at 10:29 AM. |
05-16-2012, 08:42 AM | #2 |
| Re: need advice, setup on budget 200$
Before I got anything, I'd swap those tires.
05-16-2012, 11:04 AM | #3 |
Pebble Pounder Join Date: Jan 2010 Location: League City
Buy a star and keep your eyes on the classifies. . You could find some good stuff cheap!
05-16-2012, 11:45 AM | #4 |
Rock Crawler Join Date: Nov 2009 Location: poteau
Tires, good servo, and a bec. That'll probably soak up that budget!
05-16-2012, 12:01 PM | #5 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
I'm not sure that $200.00 will quite do it. |
05-16-2012, 01:26 PM | #6 |
Rock Crawler Join Date: Oct 2011 Location: Warren
I am not sure that $200 will build you a winning comp crawler, but you can do alot with $200 if you do it yourself. I have built chassis, 4 link plates, comp rings, and links for my crawlers. I would look into building your own chassis. I made mine with a 1/8th sheet of aluminum ($10 and made 2 chassis, rock rings, and there is still more left), a $20 jig saw, metal files ($ and a little imagination. Well worth the time and effort. I dont know that I will be winning any comps, but I made my parts and am having a good time doing it. I think that Practice is one of the most important things you can do and it is free. |
05-17-2012, 09:21 AM | #7 |
Rock Crawler Join Date: Dec 2009 Location: Beaumont, Tx
Tires $30.00, CS-170 servo $90.00, bec $20.00, chassis & get everything low???$$$(used ff4 or gatekeeper). Delrin homemade links $10.00.
05-17-2012, 10:16 AM | #8 |
| Re: need advice, setup on budget 200$ In your case? First up, tires- I run Rovers (white dot compound) and love 'em. Then shocks- in your case either shorter ones, or move the top mounting points a lot closer together, or at the very minimum run the absolute softest springs you can get. That chassis' just sitting way too high for any good sidehill/off camber stability. my first mod was aluminum steering linkage $18 then a tray on the front axle for the battery to sit right next to the servo $Free You've alread got my next step, AL links I'm right now stalled in the middle of doing the XR mod until I can get my hands on some OD gears for the front. But I don't think after you take care of tires and suspension, that the XR mod will still fit under the $200 limit. |
05-17-2012, 07:13 PM | #9 |
Rock Crawler Join Date: Jun 2011 Location: San Diego
Just get tires, a servo, and a lipo (and a charger if you don't have one). If you have anything left over spend it as the truck breaks, cause it will break. Over and over again. Once you get a strong servo with a metal tie rod (connects the two front wheels, allows steering) the knuckles and chubs will break if they are plastic.
05-18-2012, 05:36 AM | #10 |
Perhaps i did not explain correctly. 200bucks is the start investment amount. was curius were to start swapping. hot rover, weels, fx-r, 35t Hw tekin, CCbec, savöx Ti-20kg servo that is what i have and then 200bucks or so. so the most bang for 200$ was perhaps a better explanation. were woud you start? thanks again. |
05-18-2012, 06:20 AM | #11 |
if you have tires and all good electronics start on the drive train. aluminum knuckles and c-hubs, rear lock outs, front cvd's, and all robinson racing metal trans gears, and some MIP drive lines. over $200 but just do it as they break.
05-18-2012, 09:37 AM | #12 | |
| Re: need advice, setup on budget 200$ Quote:
Everything else is what I would also do. | |
05-18-2012, 10:13 AM | #13 | |
IMO... Mod 1: battery mounting plate on front axle Mod 2: Lower your suspension 'til the upper links are just about parallel with the ground. Mod 3: Practice. Learn to drive your rig Mod 4: XR steering mod Mod 5: While you have the axle apart might as well see if you can find some OD gears to throw in there Mod 6: UD gears in the rear axle | |
05-18-2012, 10:27 AM | #14 |
1. Chassis w/ derin or Ti links. and shocks. 2. Xr steering mod 3. over and under drive gears 4. Steel output gears in the tranny, with steel or alum gear upgrade. These first three will put it over the top! You will not believe the difference. Pratice all the time and inbetween each mod. |
05-18-2012, 03:33 PM | #15 |
Rock Crawler Join Date: Nov 2011 Location: Wister, OK.
I think what you need is a consultant. I tell ya what, for $200 I'll stand behind you and say stuff like "looking good!!", and "yep, thats the line!!", and things like "you got this one...let it settle..let it settle down, yeah now real easy, slow, slower, now drive it out...there ya go, whose the man?? You da man!!!" Just kidding.....or AM I? So...you need my paypal info? |
05-18-2012, 03:43 PM | #16 | |
05-18-2012, 03:58 PM | #17 |
| Re: need advice, setup on budget 200$ |
05-18-2012, 10:05 PM | #18 |
| Re: need advice, setup on budget 200$ Just wait for it to break. It will break. |
05-19-2012, 12:26 AM | #19 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
Wow did anyone mention tossing the skid In my book: Get a star Get rid of the drive shafts. I use traxxas half shafts with good results, i get a pack of 6 and in the beatings of my car I think ive blown 2 and replacement was quick and easy. And cheap Keep your eyes out for used Rovers, they maybe used but they sill work Get some adjustable offset rims, they are handy and let you adjust the car easily and are a lot nicer quality than the stock ones (peek around, some people have good deals) but those can wait, getting good tires is more important Delrin links are easily made and besides tires makes a huge difference crawling. Ill never forget my first time out on Delrin links, I swore the car glided over stuff that would normally hang it up. It was amazing I got a heap load of Delrin in my shop so I could prob chop off a few pieces for you Get rid of the stock chassis... it is the worst thing ever created anything is an improvement over it. Even a simple homebrew design can do better, again look around, you never know what someone is getting rid of for cheap That and just get some drive time in on the car, make a simple course and start simple and go from there. Don't expect it to crawl over your car out of the box but making decisive decisions on upgrades saves you $ in the end and lets you really see what made the big difference overall anyways . And don't be scared to ask questions. We don't bite THAT hard |
05-20-2012, 12:31 AM | #20 | |
PASS!! for now. | |
need advice, setup on budget 200$ - Similar Threads | ||||
budget brushless setup for Wraith?'s | R/CMaxximus5.0 | Axial Wraith | 20 | 09-16-2011 02:13 PM |
Need ESC and Motor advice (on a budget) | JACZOR | Electronics | 1 | 01-07-2011 05:06 AM |
lwarc's budget fj instascaler($200) | lwarc | Tamiya XC/CC01 | 50 | 11-04-2009 05:04 PM |
