Thread: !*!*!*!GIVEAWAY!*!*!*! CreationFab Pre-Fabbed Wide Splined housing V2
Old 07-09-2012, 11:50 AM   #1
Chris_The_Battery_Man's Avatar
Default !*!GIVEAWAY!*! CreationFab Pre-Fabbed Wide Splined housing V2 *EDITED RULES*
That's right, time for another giveaway!!!!
Winner will receive 1 CreationFab pre-fabbed wide splined housings in the new V2 flavor. The V2 isn't anything fancy. Simply keeps the ears you cut off using the V1 tubes, and use a cut down stock plastic chub to keep the ends from flaring out in extreme binds. The V1 has proven a great design. But I wanted to do a different version just to give people another option.
For those that haven't heard of these, the tubes are meant to adapt XR10 universal axle shafts for more steering and much more strength. You just drop in your ring and pinion, bearings, a new set of XR10 universals, and XR10 chubs/knuckles. This puts you at XR10 width.
Sorry, the pic turned out like poo. I will post better ones when I get home
To win you must be a star holding member. If you are not, you can become one by seeing the below link:
http://www.rccrawler.com/forum/payments.php
Rules:
Post a video or picture of your truck in action
Giveaway ends at the end of this month. A winner will be chosen by a random # generator
Chris_The_Battery_Man is offline   Reply With Quote
Old 07-09-2012, 12:25 PM   #2
Default Re: !*!*!*!GIVEAWAY!*!*!*! CreationFab Pre-Fabbed Wide Splined housing V2
Dang I only ordered like $5.00 worth of stuff from you yesterday!! Ahhhhhhhhhhhh
ZippoMan is offline   Reply With Quote
Old 07-09-2012, 12:32 PM   #3
My secret agent XR running my electronics package that Chris did his super smash services on.
The package includes. Two micro sidewinders, cc bec, and a SR3500 RX all consolidated into a small shrinkwrapped package.
TedBull is offline   Reply With Quote
Old 07-09-2012, 12:38 PM   #4
All I have is ordered batteries in the past do they count ? Not that I have not wanted more. I have been looking to do a set of the splined tubes for one of my crawlers. How about this one ?
DRV KRAWLER is offline   Reply With Quote
Old 07-09-2012, 01:18 PM   #5
Holmes Hobbies
CD13's Avatar
My berg with CreationFab Mamba Micro smash job and RX bypass.
Thanks for the Giveaway Chris, CD
CD13 is offline   Reply With Quote
Old 07-09-2012, 01:26 PM   #6
I'd like to have the new version of the tubes for sure! Here's my rig running the V1 tubes...
ittybitty is offline   Reply With Quote
Old 07-09-2012, 01:39 PM   #7
Unfortunately not. This is a CreationFab Give away. Not CBP. That's my day job, and CreationFab is my side gig.
Old 07-09-2012, 01:42 PM   #8
All I'm running right now are the RX bypasses,,,,,below is my MRC but I actually run his bypasses on all my rigs!!
mgauger is offline   Reply With Quote
Old 07-10-2012, 09:03 AM   #9
Giveaway end date updated in first post
Old 07-10-2012, 09:49 AM   #10
CF Splined Tubes flying through the air!
Thanks for the chance!!
JeremyH is offline   Reply With Quote
Old 07-12-2012, 12:38 PM   #11
TSK
Shelf queen
TSK's Avatar
^^^^------ That's BADASS
CreationFab super squish electronics package powering my SA:
CreationFab powered SA video clip
CreationFab custom made chassis (the RD1c) to carry my berg axles:
TSK is offline   Reply With Quote
Old 07-12-2012, 12:59 PM   #12
My XR-10 rocking a CF dual sidewinder micro smash and wire job at ECC 2012!
Thanks for the chance.
ROWDY RACING is offline   Reply With Quote
Old 07-12-2012, 04:52 PM   #13
'm in. thanks chris.
storminator is offline   Reply With Quote
Old 07-12-2012, 09:45 PM   #14
Updated post 1 with a cleaner pic. Thought I had more, but guess not
Old 07-14-2012, 11:22 AM   #15
Spring retainers, just waiting on felsenfest delrin bodies to install them. Thx for the chance
Erin is offline   Reply With Quote
Old 07-15-2012, 12:35 PM   #16
Location: Taylors Falls just hanging with the MNRCRC crew.
I'm in thanks Chris.
By Pass adaptors in both my comp trucks.
Stormin2u is offline   Reply With Quote
Old 07-16-2012, 11:41 AM   #17
Update,
The test housing has been holding up great to some abuse. So this should work great for any of you
Old 07-25-2012, 10:36 AM   #18
Contest is now open to anyone who is a star holding member! See first post for rules.
Old 07-25-2012, 11:12 AM   #19
DickyT is offline   Reply With Quote
Old 07-25-2012, 11:56 AM   #20
Jslick is offline   Reply With Quote
!*!*!*!GIVEAWAY!*!*!*! CreationFab Pre-Fabbed Wide Splined housing V2 - Similar Threads
CreationFab's Pre-Fabbed AX-10/XR-10 hybrid housing! Chris_The_Battery_Man Axles, Trannys, T-case 18 12-22-2012 08:04 PM
CreationFab's Pre-Fabbed AX-10/XR-10 hybrid housing! Chris_The_Battery_Man Axial AX-10 Scorpion 3 07-09-2012 11:54 AM
CreationFab Pre-smashed electronics! Chris_The_Battery_Man Electronics 0 06-05-2012 10:44 AM
