08-15-2012, 07:08 PM | #1 |
Rock Stacker Join Date: Mar 2010 Location: Seattle
| AX-10 battery situation
i need some help. i accidentally bought some 3 cell lipo's for my scorpion not realizing it requires a 2 cell lipo but i like the extra power but its overheating and shutting down i was wondering if there is a cheap solution other than a new ESC any suggestions |
08-15-2012, 07:09 PM | #2 | |
I joined the Band! Join Date: Jul 2011 Location: Philippines
| Re: AX-10 battery situation Quote:
a castle bec???? i have the ae-2 esc and picking up my bec tomorrow.. then i can run 3s safely... and will be getting some 3s batteries!!! | |
08-15-2012, 07:23 PM | #3 |
how much does a bec cost?
08-15-2012, 08:03 PM | #4 |
Rock Crawler Join Date: Oct 2011 Location: Warren
A castle bec is between 20 and 25 bucks. It is a good idea to have one anyway. I would try that first to see o If it solves your problem. |
08-15-2012, 08:13 PM | #5 |
^^^ from what im hearing... having a castle bec is like having rims on your vehicle!!!!!!!!!! im getting mine lhs.. $25 |
08-15-2012, 09:35 PM | #6 |
Rock Crawler Join Date: May 2011 Location: SoCal
The AE2 system is designed for 2S. Will work but it's iffy for 3S. When you volt-up, you should gear down. Start with a 11 or 12T pinion and if the motor still runs warm, up the spur gear to whatever will fit. Between the two try for about a 25% ratio change. This will pull a lot of stress off your overworked motor. And yes, a BEC is almost a necessity if running a 3S. But also start saving for an ESC upgrade. The axial motors are cheap to replace, but the esc's cost, so you might as well go Castle SV2 when yours smokes. |
08-16-2012, 05:20 AM | #7 |
^^^^ so are you saying a 3s WILL eventually destroy the ae-2 even with a bec? sounds like your against running 3s on ae-2?? just curious... |
08-16-2012, 07:55 AM | #8 | |
A 3S with a low turn motor and/or tall gearing might make it unhappy. I ran my AE-1 last comp season with a CC BEC, a 1,300mAh 3S LiPo, the stock 55 turn motor, and stock 14/87 gearing, it worked just fine. If it wasn't for the delay between reverse and forward, I'd still be running that ESC. If an AE-1 can handle 3S, I would have a difficult time believing an AE-2 can't handle it. Invest in the BEC, pick up a CastleLink (to set your voltage to 6 volts), and fire away with the 3S! | |
08-16-2012, 08:14 AM | #9 |
ok... well that should help the OP too.. im picking up my cc bec today as i ordered it monday... so im good there.. and i just need to buy a lipo charger and batteries.. im also picking up a 500mah 2s from lhs.. $5 new... only doing it to have 1 and compare 2s and 3s as im a newbie to lipo... among-st other things |
08-16-2012, 08:35 AM | #10 |
| Re: AX-10 battery situation Against it? Not at all. But everything has a price. More voltage causes more heat, more stress. No motor or esc lasts forever, and working them harder will obviously have an effect on life span.
AX-10 battery situation - Similar Threads | ||||
What would you do in this situation? | GavinTimleck | Newbie General | 13 | 04-22-2012 05:46 AM |
How can anybody get into this situation? | GRIMGREG | Chit Chat | 21 | 03-31-2011 12:37 PM |
Econmic Situation | The Real Dogman | Chit Chat | 0 | 10-09-2008 01:55 AM |
Situation trading | Grape Ape !!! | Comments, Suggestions, and Help | 12 | 10-26-2006 01:35 PM |
my troubling situation | fuzzhead | Tamiya TLT Crawlers | 4 | 02-15-2005 04:15 PM |
