12-19-2012, 09:34 PM | #1 |
Rock Crawler Join Date: Aug 2012 Location: Etowah
| Isyeskeert's AR60 Kinda-Lightweight Build!
Maybe I was in the wrong section, but I got what seemed like a limited response from the locals... No offense to any active followers, but the Scorpion guys get all the love! Here is how I got to this point. Yes, it began life as a 'Ridge, but, I am going to show it with the other sportsman builds! Last edited by isyeskeert; 12-23-2012 at 03:35 PM. |
12-19-2012, 09:44 PM | #2 |
| Re: isyeskert's AR60 kinda-lightweight build!
Okay, I thought that this was the pinnacle. It was modified as far as the factory chassis would allow. I had done all of the mods! It was a floundering turd..... It spent more time on the roof than on the rocks! |
12-19-2012, 09:47 PM | #3 |
| Re: isyeskert's AR60 kinda-lightweight build! 6.8 lbs of RTR Ridgecrest!
12-19-2012, 09:53 PM | #4 |
So, then, I started to change my ways. I needed to give the axles a new platform. Something lighter, more nimble, I chose a Gatekeeper chassis for my new framework. This will not be the last chassis that I use in my pursuit of AR60 awesomeness! |
12-20-2012, 03:36 PM | #5 |
Alright, we'll allow it. But only because of the Betty body. I still have mine somewhere here. Got a pic from above showing the triangulation of the links with the wider axles? Did those upper link mouting plates on the axles bolt up without modification? |
12-20-2012, 04:59 PM | #6 | |
| Re: isyeskert's AR60 kinda-lightweight build! Quote:
I am currently at 4.5 pounds rtr weight. The battery, esc, and wheels will eventually all get lighter. I haven't even shortened up any of the wiring yet, since I am replacing most of the electronics and will reuse them on other projects. | |
12-21-2012, 03:41 PM | #7 |
I spent a little time reworking my rear links and rear bracket last night. I used 3/16 aluminum tube, drilled and tapped it, pretty standard stuff.... What I did get was more clearance for everything, throughout the whole movement of the rear axle. The driveshaft didn't hit before and now, it has plenty of room all around it! I am still getting "read up" on suspension geometry and this is supposed to be an improvement! |
12-22-2012, 12:03 AM | #8 |
You need to stand those shocks back up. What is your wheelbase? |
12-22-2012, 07:15 AM | #9 | |
I am at 12.5 inches on the wheelbase. The crazy proportions of the body make me think that it is too long from time to time, I love the pushed out look. When I change the body, I am going to have to do something similar with my new body. As for the criticism, I welcome it. This is my first full on build and I am enjoying it so far, but reference materials for these things are only found in the forums like RCC. I moved it to this category simply because of the ways that you Scorpion guys exchanged ideas and criticisms. | |
12-22-2012, 07:51 AM | #10 |
Yeah we're a helpful bunch. Most of us have been here at one point or another. |
isyeskert's AR60 kinda-lightweight build! - Similar Threads | ||||
Isyeskeert's AR60 Lightweight Sporty Build | isyeskeert | Axial AX10 2nd-gen | 113 | 05-16-2013 09:27 PM |
ar60 hilux truggy build | ax10newguy | 2.2 Scale Rigs | 7 | 04-02-2013 04:28 AM |
New Super Class Build...kinda... | SVEN | Chit Chat | 10 | 10-05-2011 10:18 PM |
2nd build kinda scale | clodstall | Tamiya TLT Crawlers | 32 | 01-14-2007 07:08 PM |
