01-19-2013, 10:26 PM | #1 |
Rock Stacker Join Date: Jan 2009 Location: Calgary
| Rear axle ring/pinion binding
Just wondering if anyone has encountered this before. Replaced the rear axle stock gears with underdrive gears and they keep binding. It's only in 1 spot as I spin it. I pulled the driveshaft off and didn't make a difference (just to make sure it wasn't anything to do with the driveshaft angle or tranny issue). It seems like it's possible the pinion is riding up on the ring but there is nothing to keep the pinion in one spot. Any ideas would be great! Edit: should mention, didn't think it was a worn out bearing causing a bad angle as everything was buttery smooth before swapping them out. Last edited by Tuna; 01-19-2013 at 10:30 PM. |
01-20-2013, 12:37 AM | #2 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: Rear axle ring/pinion binding
Make sure you put the gasket back in...or a new one. Also make sure the inner bearing for the pinion shaft is pressed all the way in. It may seem like it's in, but you need to press real hard to get it seated properly. Did you change locker, too, or keep the stock one? |
01-20-2013, 05:27 AM | #3 |
RCC Addict Join Date: Mar 2010 Location: Alburtis
Look at the case and see if the screws are hitting. I had this problem once. Wes |
01-20-2013, 06:38 AM | #4 |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
there are many problems that could be:screws,bearings and as the mate said,it could be the gasket.check all of them,and if not sure,replace with new parts(bearings,gasket,screws)
01-20-2013, 06:40 AM | #5 |
Pebble Pounder Join Date: Jul 2011 Location: Germany
Lockers?
01-20-2013, 06:52 AM | #6 |
Quarry Creeper Join Date: Sep 2012 Location: 01011
Wondering if the diff housing is seated properly? during an assembly I had an issue once in which the ring gear had an undercut for the diff housing to seat into. Not paying attention i assembled unevenly and had a rub issue. Apon inspection i disassembled, reassembled and the issue went away once properly seated. i agree with everyone above as well. While there isnt a ton to a diff assembly, if you dont have everything seated properly you will bind something, somewhere.
01-20-2013, 08:24 AM | #7 |
Thanks all, I'll take another look. It was a quick assembly/dissasembly so I will have to check this gasket you speak of. I didn't change the locker or anything, just simply replaced ring and pinion. I need to grease everything up good so I'll pull it apart again and report back. |
Rear axle ring/pinion binding - Similar Threads | ||||
R1 Axle Ring and Pinion play? | bbaxter51 | G-Made Crawlers | 4 | 04-16-2012 07:01 AM |
RCP ring and pinion noisy, but not binding. | sdcrawls | HPI Wheely King | 7 | 03-24-2010 05:36 AM |
Rear ring and pinion popping? | Etype R | HPI Wheely King | 7 | 09-03-2007 08:26 PM |
TLT Axle Ring-Pinion ratio? | Bsmooth | Tamiya TLT Crawlers | 3 | 02-18-2005 05:26 PM |
