Thread: Hawks NCD 2.2s
Old 10-14-2013, 01:27 AM   #1
Default Hawks NCD 2.2s
Hello people
Long time ago I wanted to build a 2.2s, but had no good cheap chassis. Last week, I then found the NCD chassis Tomy :-)
Quickly ordered and super fast delivery. Thank you Tomy
At the weekend I had time to build the chassis. It is very simple to build and everything was there ..
Here are a few pictures:
to continue
Ivo
Hawk_69 is offline   Reply With Quote
Old 10-14-2013, 03:28 AM   #2
Hey Hawk good choice. Top rig these ;)
Sent from my GT-I9300 using Tapatalk now Free
Oz Bruiser is offline   Reply With Quote
Old 10-14-2013, 04:27 AM   #3
Default Re: Hawks NCD 2.2s
Wow! Really low:-)
rofo is offline   Reply With Quote
Old 10-14-2013, 04:44 AM   #4
I know, the front shocks are too short. I only have 70mm ground clearance, making even longer rod ends to the Shocks..
approx 83mm is good.
Old 10-14-2013, 05:28 AM   #5
Why not add some preload to the shocks to lift the belly up ?
Looking good, Lets see some front and rear shots of your rig
Last edited by Haastnooit; 10-14-2013 at 06:57 AM. Reason: smartass ipad suggesting faulty words
Haastnooit is offline   Reply With Quote
Old 10-14-2013, 07:28 AM   #6
As haastnooit said. You need to pre-load the springs.. ;)
douwe is offline   Reply With Quote
Old 10-14-2013, 08:06 AM   #7
sorry I'm not sure if I understand you correctly
what is the point with the preload, the shock is no longer ... is an original SCX10 shocks
I have to make the shock longer, right?
Tanks
Ivo
Old 10-14-2013, 08:41 AM   #8
No, you have to twist the ring where the sping rests on.. On the shock body..
We all use scx shocks..
This is from my sudu (the first prototype ;))
Old 10-14-2013, 09:05 AM   #9
lol
now I understand what you mean. maybe I made the front link too long. I measure the links and write here .. Total length is 31.5 cm
the links are made ​​of carbon, if I have the correct length then I make aluminum
Old 10-14-2013, 09:11 AM   #10
It has nothing to do with the links...
Here's an easy way to understand...if you take your rig and pick it up at the skid...just until the tires start to come off the table...do the springs have a large gap between them and the nut looking thing on the shock...the preload collar?
You're running the Mini-T springs on shocks designed to run a dual spring setup. That means you need something to take up that space OR you need to spin that collar down towards the bottom so that the springs have some preload on them.
Clear as mud?
ittybitty is offline   Reply With Quote
Old 10-14-2013, 10:48 AM   #11
I have the damper still limited, which were previously mounted on double agent!
Without limitation is doing great, ground clearance is about 85mm! Thanks for your ideas .. I'll post pictures tomorrow
Old 10-14-2013, 11:00 AM   #12
If you have any further questions. Don't hesitate to ask any of the NCD teamdrivers of developers..
Verzonden vanaf mijn HTC One X met behulp van Tapatalk now Free
Old 10-18-2013, 02:17 PM   #13
So where them new pics ...
Hawks NCD 2.2s - Similar Threads
Team NCD Su Du One Oz Bruiser Axial AX-10 Scorpion 132 12-21-2013 04:34 PM
Ncd the freak luxenberg Videos! 5 07-02-2013 10:03 PM
Ncd sporty luxenberg Videos! 0 04-24-2013 05:52 PM
My new NCD Su Du One luxenberg Axial AX-10 Scorpion 13 04-01-2013 06:58 PM
MY new AX10 NCD Su Du One luxenberg Videos! 2 03-30-2013 06:16 AM
