10-28-2013, 08:11 PM | #21 |
Things are looking up in here.. with crackhead and Chris on ur tail, you'll be rolling in no time! When you tear that axle apart, make sure to do some dremel work to them uni's.. smooth the ears down on the ends at minimum.. I like goin all out tho.. |
10-28-2013, 08:18 PM | #22 |
Rock Crawler Join Date: Feb 2013 Location: york
You haven't half @$$ ed anything yet drive out the pins and do it right bro. Pm me for a little trick on them uni's I'm not ready to give up yet!
10-28-2013, 08:24 PM | #23 |
Quarry Creeper Join Date: Nov 2005 Location: Western, NC
| Re: Cheap SOB Crawler Build
PM sent |
10-29-2013, 08:14 PM | #24 |
Well, F&*K me right? $40 down the drain The pin never budged either |
10-29-2013, 08:19 PM | #25 |
Good tip chris! :banghead: I did that once... its all it took, to make sure I clamped the bottom ear in the vice before pounding it out.. |
10-29-2013, 08:45 PM | #26 |
LOL, it wasn't Chris's fault, he's been very helpful. And no, I didn't have the bottom ear clamped, dammit. Oh well, it sucks, but it's at least it was something fairly cheap as far as this hobby goes. I need my Wraith parts to hurry up, I need a good bash session, during which it will probably get broken. |
10-29-2013, 08:48 PM | #27 |
RCC Addict Join Date: May 2013 Location: York, PA
Not to sound stupid, or call you stupid.... Were you trying to drive the "big" pin out, or the "small" pin? It's of course the "small" pin that needs to come out first. If that's what you were doing, then that's some sh-tty luck right there....... My pins on all my universals drove out quite simply. I didn't even have a good punch. Just a piece of 2mm rod that I cut short and held with a needle nose, and they still came out. Serious bummer. |
10-29-2013, 08:53 PM | #28 |
The small pin, I know from MIP's over the years (and Chris) that's it's the small one that gets removed. These things weren't budging at all, no matter what, even tried a bit of heat with a torch thinking maybe they were put in with loctite, but no dice. I was using a hex key as a punch since it's tool steel, as all my punches that small are brass. My pins never moved, not even a little bit. Sh*t happens, and if I'm around, it's guaranteed. LOL
10-30-2013, 07:42 AM | #29 |
11-13-2013, 09:06 PM | #30 |
Time to get back to this one... Picked up some shaved unis, thanks Troy! I cut down some button heads for the housings, as they were still a bit long for my taste when looking through the tube Got the axle tangs to fit the spool after some massaging, and of course, a good coat of red 'n tacky Gave the cut down bolts going into the breef tubes a good coat of this stuff (love the stick BTW!) And put a dab of CA on each button head to secure them further Tomorrow will be finishing the front axle, and tear down on the rear |
11-14-2013, 06:19 PM | #31 |
Got the front end almost done tonight. Rather than keep up with those tiny bushing axial likes to use in their knucks, I drilled mine out just a hair, and used these traxxas screws, voila no more bushings to keep up with Got the knucks installed, and running a gear head RC plate for my servo and battery up front Making the tie rod was what I dreaded most, but I'm happy with the outcome. Tie rod will sit well above centerline That $15 tubing bender paid for itself tonight, steering arm bottoms out as the tie rod just touches the housing That should do |
11-14-2013, 07:10 PM | #32 |
Looks good bro.
11-14-2013, 07:31 PM | #33 |
Thanks Chris! I'm getting antsy now that I'm getting close. Got go back to work in a bit, think I'll tear the rear down first though.
11-14-2013, 07:33 PM | #34 |
Do you plan on shaving those tires
11-14-2013, 07:35 PM | #35 |
| Re: Cheap SOB Crawler Build |
11-14-2013, 07:41 PM | #36 |
Side wall tread. Shave them off get a narrower tire and will preform better just be careful not to shave to much off
11-14-2013, 08:35 PM | #37 |
Gotcha, so then shave the sides down pretty much flush with the sidewall or leave a little bit of lug for some side bite?
11-14-2013, 08:36 PM | #38 |
No lug just flush
11-14-2013, 08:42 PM | #39 |
Gotcha, I'll shave 'em down then. I did my boggers last week, curved body scissors work great.
11-14-2013, 08:58 PM | #40 |
I use curved body scissors then a drum sander 80 grit to take the lugs down to the side wall then blend it all in with a wire wheel for the dremel.
Cheap SOB Crawler Build - Similar Threads | ||||
Noob attempts to build Cheap Clod Crawler | fletty999 | Tamiya Clod Buster | 11 | 10-08-2011 09:19 AM |
One lucky SOB!!! | DonsATV | Chit Chat | 6 | 05-17-2011 10:44 AM |
Lucky SOB | Mechanicalbob | Chit Chat | 14 | 05-22-2007 11:11 PM |
