12-03-2013, 09:34 PM | #81 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
| Re: Cheap SOB Crawler Build
an if u can get some glod springs on there will help you out some as well
12-04-2013, 03:44 PM | #82 |
Quarry Creeper Join Date: Nov 2005 Location: Western, NC
I'll pick some up if I don't have them (bought a bag of springs on here recently) Did some work last night. Carefully cut my links down to get a 12.25" WB, got the drive shaft angles where I want them, laid the shocks down, moved my upper links, added chassis spacers / stiffeners, and got my body mounts where they need to be. I'm around 2.5" under the skid, got SCX shocks coming too. Once I get my electronics trimmed up and wired in, she's ready to rock n roll. Obligatory poser shot Last edited by hpiguy; 12-04-2013 at 03:54 PM. |
12-04-2013, 04:19 PM | #83 |
looks better move the rear shock back 1 hole take it an try it an see if its not better . im sure it will be |
12-04-2013, 04:21 PM | #84 |
when u get the scx shock I think I had the 2 holes in on each end . mini t green springs out back silvers up front an 30 wt oil |
12-04-2013, 04:33 PM | #85 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
Put those rear upper links on top of the axle plate, and move your rear shocks back a hole for those shocks. SCX shocks work good in the top front or one back hole in the front and the middle bottom hole in the rear. I liked running the MRC blue springs rear and MRC silver on the front with 30wt. oil. Check out my build thread on the Ringer if you want a very dialed in car. Last edited by cboggs; 12-05-2013 at 08:18 PM. |
12-04-2013, 04:38 PM | #86 |
RCC Addict Join Date: May 2013 Location: York, PA
Shaping up to be a very sweet rig. Nice job. Sucks having all these guys that know exactly how to dial in your chassis, huh? Lucky bum...... |
12-04-2013, 05:51 PM | #87 |
ya I had ho beff with mine at all I ran nabail I think is his name an he drives a natts wining ringer an our setups were relly close to one an others. you will find what I say works needs fine tunning but it would be really close . we all seem to run alittle diff setups to what we drive on an personal preffs |
12-04-2013, 11:00 PM | #88 | |
Thanks again guys, I'll make those changes and check those threads also. Quote:
Cleaned up the electronics tonight, and UPS hosed me on a part that was supposed to be here by 8PM, so I'm stuck till tomorrow. I had this before Decided to try my first smash, pile of leftovers on the right (still need to heat shrink the bullet connectors) Last edited by hpiguy; 12-04-2013 at 11:06 PM. | |
12-05-2013, 07:44 PM | #89 |
Couple more updates, Savox 1231SG, Racer's Edge dual clamping horn, and Crawler Innovations servo clamp / guard. I also moved all the upper links to the top, got my electronics mounted, and took it for a quick spin inside to test everything. |
12-05-2013, 08:26 PM | #90 |
Rock Crawler Join Date: Feb 2013 Location: york
The rig is shaping up rather nicely bro
12-05-2013, 08:56 PM | #91 |
Thanks Chris, it's getting there, a little bit at a time.
12-14-2013, 04:29 PM | #92 |
Got my SCX shocks built up tonight using cboggs seutp (thanks cboggs!!). Also, what are the rules on cutting my body to follow the lines of the rear links for breakover? I mean, where is the height of the body measured from; from the tallest point, or the shortest where I cut it at? Last edited by hpiguy; 12-14-2013 at 04:32 PM. |
12-14-2013, 05:25 PM | #93 |
Body can be cut anywhere as long as you have a minimum of 3" on the side, usually ends up being from the top of the windshield area down from there. Minimum 12.5" length and 5" width. Width will also usually be the same area for your measurement as the side.
12-14-2013, 05:56 PM | #94 |
Good deal, thank you sir!
12-16-2013, 08:50 PM | #95 |
Did some more work on the rig tonight. Got my SCX shocks installed, and removed the Losi shocks, which may end up on the Wraith. Huge difference in size and weight. I also beveled and rounded my rear left lower link that was interfering with an upper link. I think I'm going to add a small spacer under the frame side of each upper also. |
12-16-2013, 09:20 PM | #96 |
Do you plan on beveling both the links? Sent from my SM-T310 using Tapatalk |
12-16-2013, 10:29 PM | #97 |
Looking much better, have you got to run it yet since the change?
12-17-2013, 06:16 AM | #98 | |
| Re: Cheap SOB Crawler Build Quote:
Thanks, I haven't gotten to run it since it was in the old frame actually. Either family commitments, or weather has put a stop to fun every weekend. | |
12-18-2013, 11:33 AM | #99 |
move the bott. of the shock to the outside of the mount an put the link an a spacer in the mount . this will make the shock clear the link
12-18-2013, 03:56 PM | #100 |
The shock clears ok, the bottom link actually binds into the upper link, but only on that side.
Cheap SOB Crawler Build - Similar Threads | ||||
Noob attempts to build Cheap Clod Crawler | fletty999 | Tamiya Clod Buster | 11 | 10-08-2011 09:19 AM |
One lucky SOB!!! | DonsATV | Chit Chat | 6 | 05-17-2011 10:44 AM |
Lucky SOB | Mechanicalbob | Chit Chat | 14 | 05-22-2007 11:11 PM |
