01-14-2014, 07:47 AM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: Spain
| shock position?
Hello. I was thinking about about how the position of the shock , more or less sloped, afect to the torsion of the car and how the tilt of the shock afect to the shock behaviour. What do you think? Thank you. PD: Excuse me but these are very technical words so perhaps my english is not very good. |
01-14-2014, 08:16 AM | #2 |
If I'm understanding what your asking.. The more slope in the shock, the softer your setup will feel. Stand them up more vertical and your setup will be stiffer. I personally like my front shocks a little stiffer, as to hold the chassis solid and planted) and my rear shocks softer an leaned forward, as to let the rear end just follow the line of the rock ur crawling and not push back on the chassis.(specially for side hills and off camber crawling. It really holds tight to the rocks) Last edited by winnerone23; 01-14-2014 at 08:19 AM. |
01-16-2014, 04:49 AM | #3 |
| Re: shock position?
Thank you very much!!! This was that I was asking for!!! And please, let me another question.... more slope in a shock.....how it affect to the articulation of the car (to the front axle respect to the rear axle)? Thank you |
01-17-2014, 04:04 PM | #4 |
RCC Addict Join Date: May 2013 Location: York, PA
| Re: shock position?
The more you lay the shocks down, the more articulation you will get before the shock bottoms out. Shocks closer to vertical will afford less articulation. Also, shocks further outboard on the axle will articulate less, but give stability. Shocks closer to the center of the axle will articulate more, but can make the car "feel" loose. |
shock position? - Similar Threads | ||||
Shock position | SerpentCT4S | Axial SCX-10 | 3 | 02-04-2013 11:24 AM |
Shock Position Differences ? | Boostmeister | Axial Wraith | 2 | 04-16-2012 08:14 AM |
front shock position | ebomb | Axial XR10 | 2 | 10-03-2010 09:37 AM |
shock position | papabash | Duratrax Cliff Climber | 2 | 04-02-2009 01:06 AM |
DX6, replacing the 2 position gear and aux switches for 3 position? | 666 | Electronics | 10 | 04-30-2007 11:23 PM |
