01-11-2015, 10:04 AM | #1 |
Newbie Join Date: Jan 2015 Location: Orange
| Questions, new ax10 build
Hey guys! In the process of an ax10 scorpion build. I have a couple questions. I added the strc servo/battery/4 link plate to the front axle. I wanna run a 2s lipo. Cannot seem to find a pack that'll fit. I need 44.45mm wide by 57.15 long. Can probably wiggle a hair more. I would also like as much run time as possible. Any thoughts/links? I've also added the aluminum links. Straight front lowers, 30degree bend on the rear lowers. The questions I have are for configuration. I've seen a lot of different set ups. Fronts, should the link or shock be inboard? Spacers or not? Inside the chassis or outside the chassis plates? My center skid has the openings for the links. Rears, same questions. Pro/cons? |
01-11-2015, 10:29 AM | #2 |
| Re: Questions, new ax10 build
Sorry my math was off, seems the max amps 2000mah 2s will fit. Still need alittle help on the links. Thanks guys! |
Questions, new ax10 build - Similar Threads | ||||
AX10 Questions | diabloed | Axial AX-10 Scorpion | 20 | 10-29-2011 12:56 AM |
Used AX10 Questions | forbid89 | Newbie General | 8 | 02-17-2011 04:02 PM |
AX10 Questions | nightcrawler86 | Newbie General | 17 | 05-17-2009 09:54 PM |
First TLT Build (with AX10 maybe CR-01 tranny)>>>> Questions | TheHeadHunter | Tamiya TLT Crawlers | 2 | 05-19-2008 04:25 PM |
ax10 questions ... | regal200021 | Axial AX-10 Scorpion | 2 | 10-08-2007 07:49 PM |
