09-05-2015, 10:20 PM | #1 |
Rock Stacker Join Date: Jan 2009 Location: halfway
| Ax10 gearing.
Anyone have the stock spur and pinion tooth size? I burned up a motor today, brushed 27t epic. And just curious as to where i need to be with gearing on this thing. In running a rooster crawler esc on 2s lipo. Going to find a nice 35t asap and dont want to hurt it. Also, recomendations on a brushless setup that wont break the bank? Sent from my SPH-L710 using Tapatalk |
09-06-2015, 03:19 AM | #2 |
Pebble Pounder Join Date: May 2015 Location: nesbit
| Re: Ax10 gearing.
To help you better, what will you be doing with the rig? Crawling technical? Want a go fast or just trails? Gearing, type of motor turns etc. Play a big role in setting up your rig!
09-07-2015, 12:11 PM | #3 |
| Re: Ax10 gearing.
35t brushed and crawling/trail running is what i will do. Will be a scale rig once the scx shows up. Will be building a tube truggy out of both. Eventually i will go brushless on 3s. Sent from my SPH-L710 using Tapatalk |
Ax10 gearing. - Similar Threads | ||||
Wraith vs AX10, adjusting gearing for weight and voltage | steve_rolfeca | Newbie General | 3 | 02-20-2015 10:33 PM |
ax10 re gearing is it worth doing | sperd | Newbie General | 5 | 01-28-2013 01:52 PM |
AX10 with 17.5 gearing?????? | jreckner | Axial AX-10 Scorpion | 2 | 03-05-2011 05:54 PM |
What Is Ideal Gearing for a 55T Motor on AX10? | alexchen86 | Axial AX-10 Scorpion | 10 | 02-19-2010 04:14 PM |
Hot Racing AX10 axle gearing/motor combo? | Espeefan | General Crawlers | 22 | 12-28-2008 04:55 PM |
