02-07-2016, 11:43 AM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: Spain
| Motor drag brake?
Hello. I need a little more speed but it has to be a cheap solution!!Now I have a Holmes Hobbies 35T, 20t pinion and a microsidewinder (full drak brake) : Option A. 22T (2 more teeth) and the axial spur 87t (87/22=3.95). Option B: 15T and a 60t spur (both 32pitch) (30/15=3.95) What option do you recomended me? I would like to have the more possible "mechanical drag brake" I donīt know if this change would affect to drag brake of the car or not. Excuse me if my explication is not very clear. Thank you!!!!! |
02-07-2016, 11:51 AM | #2 |
| Re: Motor drag brake?
Your over geared now.. So gearing up more, will take away from drag break.. Gear down, volt up! If your not running 3s, go 3s.. If you are running 3s, go to 4s.. Then again, a few 4s packs and you could buy a new motor.. Catch 22.. |
02-08-2016, 06:12 AM | #3 |
Ok. I'll catch 22...because in this form I have the same replacement parts for all my cars. Thank you |
03-16-2016, 03:32 AM | #4 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
Volt up
Motor drag brake? - Similar Threads | ||||
Motor turns and the inducted drag brake effect...? | mr lee | Electronics | 6 | 03-13-2012 07:55 AM |
Cheapest esc/motor combo that has good drag brake? | CentralCoaster | Electronics | 11 | 05-10-2010 10:09 PM |
Drag brake on brushed motor | setecastronomy | Electronics | 2 | 07-20-2009 09:30 AM |
