Thread: Zero Ackermann Steering Options?
Old 04-18-2017, 03:10 AM   #1
Default Zero Ackermann Steering Options?
I don't like the Ackermann effect on my AX10. Cause i think it don't work well with an locked Diff. Is there an cheep mod for it?
I found several options for the scx10, which is ok i think, cause it's the same axle. Or do i overlook something? I found the following available options:
, ,(SSD00170) by SSD Pro Steering Conversion Kit
or
for Axial SCX10 #VPS02862, ,(VPS02862) by Vanquish Aluminum 8 Degree C-Hubs Clear Anodized
for Axial SCX10 AX10 Honcho Dingo #VPS02856, ,(VPS02856) by Vanquish Aluminum 8 Degree Knuckles Grey
Which steering link length is needed for the vanquish setup?
can't find the vanquish zero ackermann knuckles on stock (discontiniued?)
The other replacement Knuckles i found from strc, gpm... looks like the og with ackermann. Is it a problem to have ackermann effect in the rear and zero ackermann in the front using 4ws? Cause i would move the front setup to the rear then.
Another option i have is to change to ar60 axles front rear. If they fit . Would this be better and what benefits would bring these.
Thanks for your opinions.
magic_yeti is offline   Reply With Quote
Old 04-18-2017, 04:25 AM   #2
Default Re: Zero Ackermann Steering Options?
The most important info, for us to help you, is....
What are you trying to do with your Crawler?
Is it for fun? Comp crawling?
Do you want performance gains, that are noticable?
Do you want to spend money one time or twice?
Do you have needed knuckle weights?
Do you want 8° or non 8°?
Since it seems like you are starting from scratch, with a stock axle...
Your cheapest knuckle, that will give you zero ackerman, better steering, knuckle weight, 8° and non 8° options, that can come with a tie rod, and gives you the option of C's, is..
Dlux V2 knuckles, in brass..
You can use them with the stock C's or wraith/XR knuckles..
The catch to this is.. doing the XR width mod, to your axle and running XR Universal's.
I'm pretty sure, Dlux has everything you need @ Dluxfab.com or send him a PM.
Stay away from strc, integy, gpm, and similar junk...
Sent from my XT1650 using Tapatalk
winnerone23 is offline   Reply With Quote
Old 04-18-2017, 05:07 AM   #3
Thx for your post.
I do it for fun as first, maybe later sometimes i will go to comps.
Of cause i will gain performance, but i started without xrmod and i have weighted tires and bras beeftubes in the axles. So i want to avoid the XRMod, but if it's nessesary .... the weight balance is 60% front 40% rear right now. So i'm not in the need for knuckle weights but how knows what comes And i want spend money once.
I will have a closer look to the dlux knuckles.
Which are the benefits of 8° or not?
Old 04-18-2017, 05:11 AM   #4
Custom Carbon Fiber
Robbob's Avatar
If you do the Xr mod and use Wraith C's we have these, they use real ackerman.
Carbon Fiber Steering Arms
We have more going in stock this Friday
Robbob is offline   Reply With Quote
Old 04-18-2017, 05:41 AM   #5
Thx also.
had a look on the dlux knuckles, wow many options
but i think for a just 4 fun crawler it's a little to expensive ...
to go to comps in my sight i have to do a complete comp build. So little betty is just 4 fun ...
I want to gain just a little better steering eliminating the ackermann effect and try 4ws
Old 04-18-2017, 07:21 AM   #6
Also found this as an alternative:
Crawler Lenksystem MechaPlus für SCX10 Axial CLM #6181 | eBay
what do u think? it fits better my budget
Old 04-20-2017, 02:09 AM   #7
You may want to take a look at the "crawlster steering systems" as well:
https://www.crawlster.de/
They seem very well engineered and executed.
Stollenritter is offline   Reply With Quote
Old 04-20-2017, 08:23 AM   #8
thx i stumbled also over these option.
But i have now decided to ordered the mechaplus option, to give it a try.
Cause it's the cheapest so far.
Also thx to all others i appreciated your comments.
Old 04-22-2017, 10:46 AM   #9
Mechaplus steering arrived today.
Will post in little Betty's thread how it work out for me.
Gesendet von meinem Nexus 5 mit Tapatalk
Old 04-24-2017, 08:27 AM   #10
cheaper is not always better...thats where the spending money once or twice comes in.
those options look nice but i have learned from experience, thank you integy, that you pay for what you get.
hope that works out for you and good luck!!!
jason1973 is offline   Reply With Quote
Zero Ackermann Steering Options? - Similar Threads
VP ackermann steering or factory setup eastside Axial Wraith 5 10-03-2013 10:39 PM
Steering options? jado6006 EnRoute Berg 1 04-27-2012 04:41 PM
NAS - No Ackermann Steering Garrett Tamiya TLT Crawlers 5 01-14-2010 04:35 AM
steering options ASRCRAWLERS EnRoute Berg 13 04-03-2009 08:52 PM
steering options? emaxxjeremy Tamiya Clod Buster 12 09-07-2006 07:37 PM
