05-10-2017, 07:53 AM | #21 |
| Re: Sporty setup help - Unstuck Chassis It looks like cutting the chassis straight down behind the link mount holes would clear the motor. The pic is dark though so it could be that the whole forward link mount section would have to be removed. I guess I'm used to my Dlux transmissions, the mounting holes are slotted so I can move them as needed. |
05-10-2017, 02:21 PM | #22 | |
Rock Crawler Join Date: Jan 2008 Location: P-TOWN
| Re: Sporty setup help - Unstuck Chassis Quote:
Un mirror your trans and it will fix your problem. Your trans holes will line up and motor wont hit the chassis. | |
05-11-2017, 09:00 AM | #23 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
I UN-mirrored the transmission last night just to get everything to fit and drive it again. Luckily the forward direction torque twist is still minimized like it was testing with the mirrored trans. Tried a couple test lines on my concrete steps and the rig did what it was supposed to do in both directions. It does torque one way really bad in reverse. But I don't expect that to be a performance issue going forward. Thanks for all the help guys. Dana |
05-11-2017, 10:14 AM | #24 |
| Re: Sporty setup help - Unstuck Chassis |
05-12-2017, 04:51 PM | #25 |
You pretty much have a choice if you want the rig to perform. Set the suspension up to go forward really well and suck in reverse or do badly forward and reverse.
05-12-2017, 05:13 PM | #26 |
Exactly. I choose forward ;) Sent from my iPhone using Tapatalk |
Sporty setup help - Unstuck Chassis - Similar Threads | ||||
Getting Unstuck with HilltopRcCrawlers | doug.steele04 | Team Losi Comp Crawler | 8 | 02-20-2017 08:40 PM |
Another UnStuck is born | kmnss | Axial AX-10 Scorpion | 28 | 12-30-2016 10:04 AM |
I'm Unstuck by RC! | ROCKCRUISER | Axial AX-10 Scorpion | 13 | 07-06-2016 03:08 AM |
sporty chassis | Alamo71 | General Crawlers | 3 | 12-29-2013 05:56 PM |
