01-11-2022, 01:49 PM | #21 |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
| Re: New (old) rig - AX10 I think
I ordered up some 100mm Desert Lizards for the front and a set if 110mm Desert Lizards for the rear. Once they arrive next week, I will get them installed and see how she does. Then figure out the body situation and see how she performs. I think I also need to look into a different servo horn, or mod the existing one to move it a little farther away from the draglink. Or, rotating the C-Hubs one more notch and see what that does. |
01-11-2022, 02:53 PM | #22 |
you realy need to move the battery ether to the upper links or on to the axle it will be so much more stable that way and it puts the weight of the battery on the front axle or atlest some of it i use a peice of thin plastic and zip tied that to my upper links and mount my battery to that and to save weight im using 18650 batterys so i get 5200mah battery pack that ways about asmuch as a 1500 mah lipo the 18650 pack is only good for 40 amps but thats more than my 45t novac rockstar draws so its ok i have litteraly crawled rocks that were over verticle maybe 93°angle although that might be more the tires than the set up lol Last edited by ferp420; 01-11-2022 at 02:57 PM. |
01-11-2022, 03:07 PM | #23 | |
| Re: New (old) rig - AX10 I think Quote:
01-11-2022, 03:14 PM | #24 | |
01-11-2022, 03:17 PM | #25 |
check this guy out his batterys are dirt cheap but shipping again but he might ship to ak https://jag35.com/collections/reclaimed |
01-11-2022, 03:23 PM | #26 | |
I'll take a look around town and see what I can come up with. Thanks for the info ferp | |
02-15-2022, 09:47 PM | #27 |
Rock Crawler Join Date: Oct 2011 Location: smithville
What car is that ram body on? Looks like a capable crawler! I’m thinking of building a new crawler so that’s why it piqued my interest.
02-15-2022, 10:06 PM | #28 |
It’s an AX10. I bought it with wide 2.2 tires and the Jeep body. I.changed a few things and put on some tall skinny tires. It should be a fun little crawler. |
New (old) rig - AX10 I think - Similar Threads | ||||
Can a ax10 be used as a trail rig. | Paul1234 | Axial AX-10 Scorpion | 9 | 09-01-2013 06:08 PM |
