08-26-2008, 12:54 AM | #501 |
Rock Crawler Join Date: Jun 2008 Location: Grants Pass OREGON!
08-27-2008, 11:40 AM | #502 |
Newbie Join Date: Jul 2008 Location: Gilbert
| NeW & First Crawler
AX-10 Kit(first RC kit I've built) Integy 45T Lathe motor Novak Rooster Crawler edition Futaba 2PH radio Futaba S3003 Servo (going to upgrade to a HITECH 645MG in a few weeks) built the Tranny in a mirrored config to help with torque twist built the shocks in the limited travel config stock wheels and tires |
08-27-2008, 04:02 PM | #503 |
Rock Stacker Join Date: Apr 2008 Location: Australia
This is my axial so far. Tcs xtrail chassis. Original shocks, but with wheelie king coils up front. Coming soon. New bling wheels and tires. Twin rate coil overs. + more. |
08-28-2008, 06:26 AM | #504 |
Quarry Creeper Join Date: Nov 2007 Location: Northern
Axial AX-10 with CKRC rockstar chassis Stock transmission with VF dig CKRC stage two suspension kit CKRC split battery packs CKRC high angle front cvd's HR high clearance knuckles and axle C's HR straight axle kit RC4wd punisher shafts RC4wd TracGear lockers RC4wd narrow 2.2 beadlocks Panther cougars w/ memory foams and solid foams on outside TCS 4 link front and rear Sidewinder ESC Integy 65t Spektrum DX6 JConcepts Illuzion body |
08-28-2008, 07:06 PM | #505 |
Newbie Join Date: Jul 2008 Location: toronto
| almost finished
ax-10 so far i found the short mip drive shaft for dig unit it fits very nicley ax30465 machined hi-clearence links ax30464 ax10 scorpion joints aX30497 UPPER LINK PLATE AX30395 SCORPION HEAVY DUTY GEAR SET AX30122 SCORPION ALUMINUM SHOCK BODIES AXA1322 7X70MM POST GREEN AXA1306 6X6MM SPACER GREEN drive shafts esc+brushle4ss motere stage 2 suspension ckrcskid CKRC Delrin Skid Plate With Stage 2 Cut Outs vf dig two screws and front outdrive gh front hubs hitec 300in/pounds steering servo upper link bracket hd axel diflocks carbon upper plate flat iron prolines tires black rockstar axel wheels mem foam hpi 7154 bug body dx3r trax/reciver 7.5 ox per front wheel lead stick on front axel battery plates 7 cell split battery deans pluge1 axa1302 spacers small axa1101 tapered washers scp3801 metal trany case scp1000t trany metal gears SCP888H Hard Anodized 88T Alum. spur gear SCP133WH01 Black Adj.chariot Skid wheel 2667 BIG BORE SHOCK ALUM CAPS (2) 1012 12T 48P Pinion mip-ds15 short drive shaft for dig SKU31008 Tube Frame (Black) SKU34803 TCS Edge hardware kit SKU3600111 TCS Edge Black Vinyl Sticker Last edited by fuceye; 08-28-2008 at 08:11 PM. |
08-28-2008, 07:08 PM | #506 |
Quarry Creeper Join Date: Dec 2006 Location: Western Mass
I'll add mine in for posterity sake. Had it awhile, light mods. It's a fun truck! still have a few green links to strip... Mayhem DPs with FlatIrons STRC bent links 55 integy, Mtroniks esc |
08-28-2008, 09:43 PM | #507 |
Pebble Pounder Join Date: Apr 2008 Location: Tulsa
Some updated pics. Current goodies Sidewinder ESC CC BEC DNA Dig Rock Claws Integy 55t Dx3.0 Maxamps 3C Lipo 70W in Rear and 80W in front shocks Helios body 8# Rockhammer Hybrid with 7.5Oz in front 5# Rockhammer Hybrid wigt 4.5Oz in rear *RCP Straight axle adapters RCP Stainless steel straight axles |
08-28-2008, 11:27 PM | #508 |
I wanna be Dave Join Date: Dec 2007 Location: Not here
| Mayhem Eng. I need to get some wheels Last edited by Mayhem Eng.; 08-28-2008 at 11:32 PM. |
08-29-2008, 10:48 PM | #509 |
RCC Addict Join Date: Aug 2005 Location: New Oxford PA
08-30-2008, 02:48 PM | #511 |
Quarry Creeper Join Date: May 2007 Location: home
Here is my Axial Crawler Losi Crawler shocks Integy 55t motor hitech 645mg servo Lipo Battery Sidewinder Micro esc few other lil things |
08-31-2008, 09:06 AM | #512 |
Quarry Creeper Join Date: Apr 2006 Location: sweethome
| Ax 10
Finally Done .to many projecs.
08-31-2008, 02:09 PM | #514 |
Newbie Join Date: Aug 2008 Location: Cape Coral
09-01-2008, 10:04 AM | #515 |
Quarry Creeper Join Date: Jul 2008 Location: us
heres mine RTR Metal links Mayhem spiders Losi Rock Claws xc-1 body |
09-01-2008, 03:01 PM | #516 |
Newbie Join Date: Jul 2008 Location: Hinckley, U.K.
Mamba Max Holmes Hobbies 7T Cobalt Puller DNA R/C DIG Ace DS1015 for steering Hitec 5225mg for dig Mayhem Engineering Beadlocks Twinset Battery/servo tray with 4 link mountings Slipper clutch Driveshaft rings still awaiting losi shocks and need to send shells to be painted but.... Last edited by plod; 09-02-2008 at 01:04 AM. |
09-01-2008, 08:47 PM | #517 |
I wanna be Dave Join Date: Dec 2007 Location: Florida
Axial Axles & Tranny w/steel gears & slipper clutch CKRC Rockstar Chassis CKRC FT Dig/ Hitec 645 servo CKRC Viper front & rear link/servo mounts CKRC Heavy duty bent links CKRC CNC Tri-Links CKRC 3s Lipo CKRC Electronics Plate CKRC Hardened lockers CKRC Aluminum servo mount CKRC Baja Bug body CC Sidewinder esc Airtronics MX3-FHSS Radio/Receiver JR 9100T Steering servo Mayhem Double Phatty comp wheels Panther Cougar tires Last edited by CrawlerGraphics; 09-07-2008 at 12:00 AM. |
09-03-2008, 10:26 AM | #518 |
stock chassis losi shocks CDW outputs and rear 4link Losi claws with custom hybrid foams Hitec 645 CC Sidewinder and BEC Novak 55t Spektrum dx3 Elite 1500 8cell 2/3a my "cheater" Losi mini LST Bronko body :-P, and my grappler that I want to comp with. Last is a betty project that turned out ok hi-lift made by myself! Last edited by helhedded; 09-03-2008 at 10:34 AM. |
09-03-2008, 12:46 PM | #519 |
I joined the Band! Join Date: Jul 2008 Location: ohio
| the first
This is my first crawler. I must say they are a blast to run. This one was a rtr but i have added a few new parts. Pro-Line hammers m3 with memory foam Novak Roster Crawler ESC Integy 55 Turn Matrix Lathe Rock Crawling Motor Custom 4 link Lower bent links |
09-03-2008, 01:03 PM | #520 |
Newbie Join Date: Mar 2008 Location: Tudela(Spain)
| My Spanish Baja Bug. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-ax-10-scorpion/82403-axial-ax-10-picture-archive-no-talking.html | ||||
RE: Anyone Have a Mini MGT? | This thread | Refback | 10-05-2011 08:59 AM |
Axial AX-10 Picture archive - No talking - Similar Threads | ||||
1.9 scale rig picture archive - No talking | 123abc | 1.9 Scale Rigs | 2041 | 03-26-2024 03:44 AM |
Redcat Picture Archive - No talking | EeePee | Redcat Crawlers | 404 | 02-08-2024 06:23 PM |
1.5 scale picture archive - No talking | 1BadJeepBruiser | 1.5 Scale Rigs | 358 | 07-04-2023 03:22 PM |
SCX10 Picture Archive - No talking | BENDER | Axial SCX-10 | 3332 | 06-04-2023 05:40 PM |
Wraith Picture Archive - No talking | Harley | Axial Wraith | 1586 | 03-22-2023 11:32 AM |
