09-08-2007, 01:39 PM | #1 |
Quarry Creeper Join Date: Aug 2007 Location: tx
| Axial SHOCK problems
Ok I know that I am not the only one with the shock problem of the tops poping off on my AX10 Scorpion. I cant even run mine over minor stuff with out poping the top loose. They all leak because even though they wont pop completly off they will pop loose one thread and thats enough to leak oil everywhere. I want to hear everybody elses sugestions on fixes because these stock ones suck. |
09-08-2007, 01:42 PM | #2 |
Quarry Creeper Join Date: Aug 2005 Location: San Juan Bautista
blue them for the time being till you can get some new ones. mine have been working great.
09-08-2007, 01:50 PM | #3 |
I am guessing you mean glue them. Will reg super glue work I dont have any CA
09-08-2007, 01:57 PM | #4 |
Also what position do you have your top mounted in??
09-08-2007, 01:59 PM | #5 |
Pebble Pounder Join Date: Sep 2006 Location: Norfolk, VA
Super glue should work, but I have always used telon tape on nitro shocks to keep them from popping. A couple wraps will work.
09-08-2007, 02:05 PM | #6 |
could I be over filling them? I just toped it off with oil and put the cap back on and squeezed it with my fingers and the top poped off. |
09-08-2007, 02:09 PM | #7 |
Newbie Join Date: Nov 2006 Location: Norway
After reading about the stock shocks, I allready got a set of Traxxas Big Bore shocks as a replacement. They seem to be quite solid, especially compared to any plastic shocks.:-P
09-08-2007, 02:09 PM | #8 |
Pebble Pounder Join Date: Jul 2007 Location: Okinawa, JP
use the spacers on the shock shafts that came w/ the kit? if not your probely bottoming them out and pushing the tops off.. I use losi xxx-nt shocks w/ the axial shafts on mine and have been very pleased
09-08-2007, 02:39 PM | #9 |
I have the rubber ones on them. They pop off even before it gets to the spacer.
09-08-2007, 02:46 PM | #10 |
:-xI would sure hate to see this thing actually try and crawl a rock. I cant even go over a small curb with out these shocks poping loose. |
09-08-2007, 02:50 PM | #11 |
OK done ranting. Now what is a good replacement shock I can use. |
09-08-2007, 02:53 PM | #12 |
Rock Crawler Join Date: Mar 2007 Location: Colorado
09-08-2007, 02:57 PM | #13 |
09-08-2007, 03:02 PM | #14 |
thats what i am thinking. I will leave the oil below the top and the shock when compressed will not come back out then I get it to the top and it is very hard to push in. I guess I just need to find a happy medium.
09-08-2007, 03:34 PM | #15 |
well I put a little less oil in the fronts and put some WK springs on it an WOW much better. I dont get near the torque steer I did have. I still want some Alum. shocks. Because these are not the greatest. Isn't Axial supposed to come out with some alum shocks to fit the AX10??
09-08-2007, 03:34 PM | #16 |
Quarry Creeper Join Date: Apr 2007 Location: Kapahulu Safeway
I had the same problem. Please don't laugh. I had mounted the o rings on the outside of the shock body and tightened the cap down just enough to create a seal without pushing out the o-ring. The cap on one shock kept popping off. I decided to read the instructions. I put the o ring inside the cap and haven't had a problem since.
09-08-2007, 03:48 PM | #17 |
Hey I wont laugh I am the moron that put to much oil in the shocks. |
09-08-2007, 07:05 PM | #18 |
Newbie Join Date: Jul 2007 Location: Santa Clara
| Bleed the shocks
I agree that too much oil is the most likely problem. When you're building the shocks, pull the shaft all the way down to the bottom and fill the shock body to the top with oil. Pump the shaft a few times to get the air out from under the piston head and let the bubbles come to the surface. Top off with oil and thread the cap on maybe 1/2 or 1 turn - do not tighten it. Push the piston all the way to the top to bleed out the excess oil. This next part is critical. Hold the shaft all the way in and tighten down the cap by hand. An easy way to do this is to push the shaft down onto your work surface while screwing the cap on. Get it as tight as you can with your fingers only. At this point, the shaft should slowly rebound out about half of its length. If it rebounds quickly to its full length, there is too much oil in the shock body. Unscrew the cap a few turns and pump the shaft a few times to bleed a little more oil, then tighten it back down. Repeat this process until the shaft rebounds properly. Now that you are done bleeding the shock, you can tighten the cap down all the way. Grip the shock body with a rag and some pliers, and stick a screwdriver or allen key through the hole on the cap. Tighten down carefully, and you're done. Repeat for the other 3 shocks. If you follow this process, you shouldn't have any more cap-popping issues. |
09-08-2007, 07:59 PM | #19 |
Hey thanks that is what I am doing. Because when I push in the shock it rebounds VERY quickly. Thanks. now to just solve this torque steer. |
09-08-2007, 08:07 PM | #20 |
Quarry Creeper Join Date: Apr 2007 Location: Harrisville, UT
also be carefull, with the cap poping off all the time, I'm guessing that the plastic threads on the body and cap are thrashed, don't be surprised if they still leak, and be very careful not to overtighten them
