11-21-2007, 09:05 AM | #21 | |
Newbie Join Date: Nov 2007 Location: SANTIAGO, CHILE
what about if i use the ax10 shaft wll extend teh lenght of the shock? | |
11-21-2007, 09:19 AM | #22 | |
Quarry Creeper Join Date: Sep 2007 Location: Elizabethtown,KY
when I install mine I didn't see too much of difference. I did try middle hole and see. overall center gravity went down so that was big thing. I end up doing more mod and my upper link is at body post location and created new upper links. | |
11-21-2007, 10:20 AM | #23 |
Newbie Join Date: Nov 2007 Location: Seattle
11-21-2007, 11:18 AM | #24 |
Newbie Join Date: Jun 2007 Location: buffalo
so the big bores do work but need to be modded? also dose anyone elses shocks leak out of the shock cap? mine do and the caps are tight but could i have just over filled them?
11-25-2007, 07:09 PM | #25 | |
Yes, the upper caps of the Big Bores have a fixed hoop on them that won't allow you to use a ball like the stock shocks, and therefore would not allow you to get the shock angles you need. Use a dremel to grind down the stock hoop on the top cap, but don't take it down flush to the cap. -Leave about 1mm of the hoop material above the top of the cap because the caps are very thin in this area. Remove the rubber diaphram and drill the cap from the underside with a 3/32 bit since they already have a center point partially drilled there. Buy some traxxas ball ends like the style that are on the bottom of the shock, then run a small screw up through the bottom of the cap into the ball end. The longer the screw you use, the more adjustable the length of your shock will be. I screwed it all the way down to the cap on mine. The shorter shock length gave me the drive line pitch I wanted. | |
11-26-2007, 01:16 PM | #26 |
I joined the Band! Join Date: Dec 2006 Location: RENO
here they are. We just got them in this morning. http://www.ckrccrawlers.com/shop/ind...roducts_id=684 |
