12-27-2007, 06:39 PM | #1 |
| Must have parts from TCS
well after the incident that left my scorpion looking like this An order to The Crawler Store was in order... but I couldn't just order the c hub and a ballend... So I also added the boomerang front and rear link/servo mounts, their axel battery mounts and added a 7 cell pack for good measure. Seems a lot more predictable now, and the extra punch never hurt any one.. I have to give it for being a very cost effective mod.. rear front servo mount, batt mount, and 1500mah pack top view can't have a update without a flex shot |
12-27-2007, 06:48 PM | #2 |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
Looks good exesivefire, I like the paint job on the H2. What did you notice doing the rear links that way?
12-27-2007, 07:06 PM | #3 |
Rock Crawler Join Date: Jun 2007 Location: Flint/Mt. Morris
Nice, I am about to order the same things. Do the 4 link mounts come with extra ball ends or rod ends not sure on name?
12-27-2007, 08:18 PM | #4 |
Quarry Creeper Join Date: May 2007 Location: Seattle
What did you do to cause that much damage? I've dropped mine 8+ feet and haven't caused that sort of damaged...congrats! I like that four link plate in the rear...if anything it looks good. |
12-27-2007, 09:24 PM | #5 |
Pssst, hey Andy. You're rear upper links are backwards. You want the driver side on top. I've been running mine that way with green springs and it works really great. |
12-27-2007, 09:25 PM | #6 |
i ordered some extra ball ends, you will need them... it fell off a 3 ft table and landed square on the wheel.... |
12-27-2007, 09:28 PM | #7 | |
Guess i am going to have to put a ribbon on the driver side, just like i had to do to tell my right hand from my left! | |
12-27-2007, 09:32 PM | #8 |
Rock Stacker Join Date: Dec 2007 Location: toledo area
why are the rear upper links setup up as 1 one top and 1 on bottom? Is this a shafty thing with axle torque? What does it help? |
12-27-2007, 09:38 PM | #9 |
12-27-2007, 11:07 PM | #10 |
I joined the Band! Join Date: Oct 2006 Location: RcFanatics.net
With the link mount on the front how does it mount? The servo mount and the link mount use the same bolts?
12-28-2007, 12:03 AM | #11 |
Pebble Pounder Join Date: Nov 2007 Location: Bay Area
good stuff exesivefire, I've run the same setup except with the driver side link in the back on top and it works great.
12-28-2007, 12:13 AM | #12 |
Newbie Join Date: Dec 2007 Location: Thailand
How much sticky weight on the front and rear did you put in your wheel?
12-28-2007, 12:25 AM | #13 |
I run 7.5oz in each front wheel just like it says to in the ckrccrawler stage 2 setup http://www.rccrawler.com/axialcompbuild.html |
12-28-2007, 01:02 AM | #14 |
hey Andy, your truck is too tall, please lower it. |
12-28-2007, 01:07 AM | #15 |
12-28-2007, 01:46 AM | #16 |
12-28-2007, 06:50 AM | #17 |
Pebble Pounder Join Date: Dec 2007 Location: CA
| Can anyone confirm which side of upper link mount ( left or right ? ) has to be above or under ? in order to eliminate the torque twist. Tks very much.
12-28-2007, 07:08 AM | #18 |
Pebble Pounder Join Date: Jul 2007 Location: Okinawa, JP
[quote=EeePee;981113]Pssst, hey Andy. You're rear upper links are backwards. You want the driver side on top.
12-28-2007, 09:29 AM | #19 |
TCS mentions the driverside one being the one that should be up top... i was just a bone head and did it backwards it's fixed now |
12-28-2007, 09:31 AM | #20 |
