Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX10 2nd-gen
Thread: C*H*U*D's Ridgecrest
Old 04-27-2013, 08:41 AM   #261
Default Re: C*H*U*D's Ridgecrest
Top links, axle housings, front universals etc... more than enough
crawl rookie is offline   Reply With Quote
Old 10-17-2014, 04:39 PM   #262
Originally Posted by C*H*U*D View Post
Just to put everyone back on the same page, my Ridge is meant to be a crawler.
The Ridge actually comes with a decent chassis for us crawlers. It's a bit heavy and bulky but does a decent job. However, I've wanted to do this project since the Wraith was introduced, so here we go.
First things first...the motor/trans has to fit. I wasn't too worried about this since this chassis is based off of the F-4 which was designed around the Axial transmission:
Since the transmission was coming out, it was a good time to replace the internals. Classic Robinson parts were slated to go in:
I went with the extended Robinson output gear. Since this truck is destined for 2.2s, dig is not allowed. I bought the Dig output, but it will not work with the standard housing. This output will be saved for a class 3/TTC truck, and the stock output goes back in:
It was time to load up my Chassis Holding Utility Device:
A few changes can be seen right off the bat:
Wheelbase is a bit too long to be legal, but that's good since I still plan to bend the lowers.
For now I'm using the stock uppers. These will be changed.
I can't remember who asked for this, but here is a shot of the inside of my rear wheels.
Juan, could you please explain to me where you mounted the esc?? I'm making a similar build but I'm unsure of where to place my new mamba max pro!
big knobs is offline   Reply With Quote
C*H*U*D's Ridgecrest - Similar Threads
C*H*U*D's Creeper C*H*U*D Venom Creeper 14 09-03-2016 07:24 PM
C*H*U*D's Sporty C*H*U*D Axial AX-10 Scorpion 145 07-26-2016 10:23 PM
C*H*U*D's LCC C*H*U*D Team Losi Comp Crawler 52 03-07-2011 04:02 PM
C*H*U*D's New F-4 Build C*H*U*D Axial AX-10 Scorpion 81 10-28-2010 10:35 AM
mc d's singing MGS511 Chit Chat 2 10-14-2006 04:31 PM
