02-28-2015, 03:27 PM | #1 |
Quarry Creeper Join Date: Feb 2015 Location: Corpus Christi
| Dig kit assembly.
So 1st post here. I recently purchased an ax10 deadbolt and atptef to install the axial dig kit the other night. First off I was not aware that I would be neededing to order 2 extra bearings to properly assemble the kit. (Thanks for not mentioning that, Axial.) I have the needed bearings on order now. I pre-assembled the trans. without the bearings to make sure that I didn't need to order anything else. All looks good except for one thing. The rear output shaft that comes in the kit doesn't really have anything to hold it in place. I can only assume that this adding the rear bearing will aid in the shafts retention, but it just doesn't seem like a good design. Is this normal?
03-01-2015, 10:00 PM | #2 |
Rock Stacker Join Date: Jan 2014 Location: Hamilton, Ontario, Canada
| Re: Dig kit assembly.
Well first off, the Digg kit is designed for the wraith, which has most of the parts needed already. The AX10 deadbolt uses a SCX10 style trans case, similar but not with the exted tail section. Ask in the SCX10 forum here about digg install. |
03-01-2015, 10:03 PM | #3 |
Also be aware that you may need to shorten the rear drive shaft as the entire assembly will now have a longer shaft in the rear.
Dig kit assembly. - Similar Threads | ||||
1/35 F-150 4X4 kit Assembly/Review | MGCrawler | Micro Scale Rigs | 35 | 10-24-2016 04:19 AM |
My JK kit assembly. | project_mayhem | Axial SCX-10 | 30 | 04-09-2013 03:06 PM |
Need Help with VP Dig Assembly | CmdrZod | Axial AX-10 Scorpion | 6 | 12-29-2010 09:17 PM |
80īs Colnago Roadbike assembly kit | Unimog | Chit Chat | 3 | 04-08-2009 09:01 AM |
DNA dig assembly problem | 72Blazer | Axial AX-10 Scorpion | 2 | 08-31-2008 10:33 AM |
