Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX10 2nd-gen
Thread: question about the vanquish knuckles I ordered did I mess it up?
Old 08-04-2017, 10:48 AM   #1
Default question about the vanquish knuckles I ordered did I mess it up?
Hi guys, I had some issues with my STRC steering links they are terrible, sure its an upgrade over stock, so I bought the vanquish incision stainless steering link set that is much better designed. The STRC ones are horrible in that they use small diameter machine thread grub screws that thread into the ball ends and then get threaded into the links, and yea not good, the link ends pull out and the threaded area loosens up.. I just bought for my ax10 deadbolt "project orange" I bought these: Vanquish Axial Wraith Knuckles Orange VPS03202 | eBay
I am running the stock c hubs stock axle housings, but I really liked the orange and its really my first real vanquish product... I also bought the vanquish bronze bushings that go into these. I just don't know if these will fit the stock c hubs, it says: Fits all Axial AX10, Axial SCX10 and Axial Honcho kits with Vanquish 8 Degree Chubs
so do I need to buy the vanquish c hubs too? I am going to get the xtra speed axle housings at some point too. The vanquish ones are silly expensive...
Thanks
-Spence
Spence is offline   Reply With Quote
Old 08-04-2017, 11:25 AM   #2
Default Re: question about the vanquish knuckles I ordered did I mess it up?
Just to clarify but I'm assuming you have an AX-10 with AR60 (wider) axles that uses Wraith parts. In that case they should fit fine.
Sneetches is offline   Reply With Quote
Old 08-04-2017, 11:47 AM   #3
I mean they are labeled as fitting the wraith, I have the ax10 deadbolt which is the 2nd gen of ax10 which is discontinued which does use the ar 60 axles which every non scx10 axial rig uses... Thanks
question about the vanquish knuckles I ordered did I mess it up? - Similar Threads
Just ordered my tf2. and I have a question or 2 mikemollic RC4WD Trail Finder 2 10 01-04-2016 02:21 PM
Ordered a ax10 deadbolt have a question coldfire General Crawlers 8 05-02-2015 07:04 PM
vanquish knuckles chubs question kowalski22 Axial Wraith 3 02-02-2015 11:29 AM
vanquish wraith link on ar60 axle with vanquish xr10 knuckles? T3rry Axial AX10 2nd-gen 2 04-28-2013 06:11 PM
