07-10-2018, 09:22 AM | #1 |
Rock Stacker Join Date: Jan 2018 Location: Ivins, the Red Rock Southwest
| AR44 10deg castor
Any good hints as to how to set the caster relatively accurately ? is the spline a good referance ?2 notches ? 3 ? |
07-10-2018, 06:41 PM | #2 |
| Re: AR44 10deg castor
You guys will get a better response in the SCX-10 II sub forum: Scale Rigs Brand Specific Tech - Axial SCX10 II at RCCrawler.com AX-10 II has AR-60 axles & a TVP-like chassis Last edited by Mike Flea; 07-10-2018 at 06:44 PM. |
07-10-2018, 06:45 PM | #3 |
Roll the c hub back a couple splines and see how it works. I'd have to think the panhard mount would be an issue.
07-10-2018, 08:17 PM | #4 |
| Re: AR44 10deg castor |
AR44 10deg castor - Similar Threads | ||||
Get your VP castor blocks while they're in!!!!!!! | ScaleReady | Axial Yeti | 13 | 05-06-2015 05:31 PM |
extreme castor angles | Maxwedge | General Crawlers | 2 | 10-14-2012 06:55 PM |
How much castor is everyone using | vypr | Axial XR10 | 9 | 04-03-2012 09:04 PM |
Castor? | ROCKST*R | Losi Mini-Rock Crawler | 3 | 03-21-2012 05:27 AM |
Castor | Briguy-01 | Team Losi Comp Crawler | 6 | 11-29-2010 11:53 AM |
