Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX10 2nd-gen
Thread: devil rc spool and gear set is tight
Old 07-03-2019, 05:02 AM   #1
Default devil rc spool and gear set is tight
I just installed a Devil RC onepiece spool and gear set on my scx10II. The axles were a very tight fit into the spool, which is fine, but the gear mesh seems way too tight. If I spin the drive gear with my fingers I can barely spin it. Do these gears need to be broke in? I expected a very smooth action with only grease resistance.
Also, I received a washer with the kit that is extra. Where does that go?
axismoto is offline   Reply With Quote
Old 07-03-2019, 05:45 AM   #2
Custom Carbon Fiber
Robbob's Avatar
Default Re: devil rc spool and gear set is tight
If you take the pinion (input shaft) out does the ring and spool spin freely in the bearing carriers? Maybe the bearing caps are too tight or the bearings arent set on the spool fully and causing a bind.
Im not sure on the washer, it may be to go between the housing and the driveshaft to take up in/out play.
If the spool spins freely with out the pinion gear then maybe the bearings arent set fully in the input side? Causing the pinion to be in too far and bind?
All else fails you could try getting a hold of Locked Up RC with questions.
SCX10 II Spools & Gears from Devil RC
Robbob is offline   Reply With Quote
Old 07-03-2019, 03:45 PM   #3
Took it apart put it back together, it works, feels good. Don’t know what it was, but it’s good now. Thanks
devil rc spool and gear set is tight - Similar Threads
How tight/loose do you guys set your gear mesh? big_poppa49 Axial SCX-10 9 11-16-2016 02:15 PM
AX30401 HD Over Drive Gear Set MESH too tight? joe.bielski Axial SCX-10 9 08-05-2015 07:21 PM
Tight gear box GiXeR Venom Creeper 6 01-07-2010 04:28 AM
