09-13-2022, 10:02 PM | #61 |
RCC Addict Join Date: Mar 2009 Location: The REAL Nor-Cal
| Re: House’s 2022 Sporty
After measuring and contemplating, I found out that the issue was the hubs not the axles, and even though it makes more sense to modify the static part I drilled out the hubs instead. Easier, quicker, and the actual problematic part, but it could be an issue later if I end up swapping hubs… Oh well, done now. Since the shafts actually measured 8mm (.315) I ran an O drill (.316) through them and they fit nice now. Surprised to see they were almost .003” small, no wonder they didn’t want to fit! Last edited by House; 09-13-2022 at 10:05 PM. |
09-14-2022, 09:08 AM | #62 |
Rock Crawler Join Date: May 2009 Location: Calgary
I had the same issue and used the same solution.
09-14-2022, 11:21 AM | #63 |
Hi Kevin! I wonder if it was an issue with a single lot from a supplier or if all the new ones are that way? I am liking the new beefy 3mm pins. I didn’t see a lot of 2.5mm pins break on their own, but I know they could be bent from tightening the set screw down too tight, and if not tight enough they come loose, slide out, bind up and break… I still like to use blue loctite on the set screws to help keep them in. I usually run solid face wheels so it is not convenient to keep tightening them… |
09-14-2022, 10:44 PM | #64 |
Mocking up some bodies to figure out a cut pattern. Figured you guys would get a kick out of this one, eh? Long live BC Paints! Last edited by House; 09-14-2022 at 10:59 PM. |
09-16-2022, 01:02 PM | #65 |
| Re: House’s 2022 Sporty |
09-16-2022, 01:49 PM | #66 |
I’ll be painting a new one, I don’t want that one beat up any more than it is… Museum piece. |
09-23-2022, 11:09 PM | #67 |
Finally got it out for a quick shakedown run. No issues so far, seems pretty solid. |
09-24-2022, 07:22 AM | #68 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
Sweet color scheme, damn thing looks like it could crawl upside down Sent from my iPhone using Tapatalk |
09-24-2022, 07:30 AM | #69 |
This body’s cab is too tall for that, maybe with one of the newer styles or 1/18 scale but I cannot stand the disproportional looks of that. I know, function before fashion, but I just can’t do it… I’ll have to take a few bodiless pics to show the final result as well. |
09-24-2022, 10:16 AM | #70 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
Thank you for sharing your build with us. Nice work sir |
09-24-2022, 01:39 PM | #71 |
Thanks Eddie, and thanks for making the best tire foams available! |
09-25-2022, 12:54 PM | #72 |
Here are some naked pics for your viewing pleasure…
09-25-2022, 12:55 PM | #73 |
Man the RCC photo software sure seems to be knocking the clarity down these days…?
09-25-2022, 05:12 PM | #74 |
The image size limit is 1200 x 600 so it could be that but I dont use RCC to host so I'm not sure whats going on. EDIT: It looks like it shrunk them down to 640 x 480. You could use a Image hosting site like Imgur then resize the pics to 1200 x 600 Anyway looks great! What was the final weight? Last edited by HumboldtEF; 09-25-2022 at 05:17 PM. |
09-25-2022, 06:49 PM | #75 |
Just a hair over 3.5 lbs. That is RTR with tungsten loaded knuckles but no loaded dice hangers on it. I will most likely run it with them, but that will still be sub 4lbs IIRC. |
09-26-2022, 08:51 AM | #76 |
Quarry Creeper Join Date: Mar 2021 Location: SOCAL
this is a bad a$$ rig Sr.... sure looks to perform as well as it looks.
09-26-2022, 06:38 PM | #77 |
Thanks ST, I didn’t get too much wheel time with it, but it felt pretty good.
10-03-2022, 09:47 PM | #78 |
Think I may give these Team Brood Kyosho Velvet shocks a try, but I might put the Dlux spring retainers on them to reduce some of the spring preload…
10-03-2022, 10:39 PM | #79 |
I think I like this setup even more…
10-05-2022, 03:05 PM | #80 |
Testing the new dampers.
Tags |
5thd, dlux, shafty, sporty, ssd |
House’s 2022 Sporty - Similar Threads | ||||
Winter hard 2022 (invernal dura 2022) | FREEDOM83 | Outside the US | 0 | 01-17-2022 02:52 AM |
