Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX10 2nd-gen
Thread: House’s 2022 Sporty
Old 05-02-2022, 10:15 PM   #1
Default House’s 2022 Sporty
Been collecting some parts for a while now, so might as well start a new build thread…
Putting it in the Axial section since it has hints of Axial design, but no actual Axial parts unfortunately.
Starting with SSD/Dlux axles and a 5D Sucker Punch chassis. Driver side drop front, mix of carbon, aluminum, and brass with tungsten slugs in the knuckles.
8mm axles f/r w/3mm pins. Fastener Express aluminum hardware and Traxxas aluminum balls in Revo rod ends…
House is offline   Reply With Quote
Old 05-03-2022, 10:44 PM   #2
Default Re: House’s 2022 Sporty
Worked on some Dlux titanium links tonight.
Traxxas Revo rod ends for the lowers and standard 1942’s for the 1/8” uppers.
Filled with hard anodized aluminum Traxxas balls…
Old 05-03-2022, 10:58 PM   #3
Location: North to Alaska - go north, the rush is on....
Those are some amazing looking parts man!!!
AK KRAWLER is offline   Reply With Quote
Old 05-03-2022, 11:57 PM   #4
Thanks!
Not sure if anybody remembers the rear tubes I built for my Berg a few years back but I was kicking around a similar design with the SSD centers for this Sporty build. I actually like my SDS style link mounts better, but Dlux saved me a LOT of time with their new axles so I didn’t have to make my own that’s for sure…
Old 05-04-2022, 06:04 AM   #5
What hard body are you going to run?
Almighty Malach is offline   Reply With Quote
Old 05-04-2022, 09:23 AM   #6
Probably a Parma X-Citer.
#compcrawlingisnotdead
#longliverccrawler
#fukfacebook
Old 05-04-2022, 02:18 PM   #7
Not that this really matters, but I took the lighter weight option building the HamBERGer transmission. Unfortunately I only have a steel locker and solid RCBros gear at this time… I think there would be a considerable weight savings going to an aluminum locker and the lighter SAF gears…
Old 05-04-2022, 08:14 PM   #8
Time to build some suspension dampers.
Old 05-04-2022, 08:42 PM   #9
Might put offset balls on the front tops, we’ll see later once more is assembled…
Old 05-05-2022, 09:20 AM   #10
I think you’re onto something here Casey…
Maybe I should put this in the 2.2 scaler section so it will get some views…
Old 05-05-2022, 10:10 AM   #11
Setting this little guy up for installation…
Old 05-05-2022, 09:08 PM   #12
Ordered an aluminum locker and some lightened gears, so these will have to be swapped out, but I decided to tear the trans apart and try a different motor forward configuration. A few small mods to do, but I think it should work out…
Old 05-06-2022, 12:57 PM   #13
should be a well built rig when its done. will perform well too.
CM9000 is offline   Reply With Quote
Old 05-06-2022, 01:34 PM   #14
Thanks
Still hesitant to replace my AX10 based sporty, but I do have high hopes for this one…
Old 05-07-2022, 09:29 PM   #15
My ghetto fab foam cutter is still working…
I wish I still had the nice one I built and gave to Erik…
Wonder if he still has it or if it went back East with the rest of the Dlux stuff?
Old 05-07-2022, 10:08 PM   #16
Might have gone east and got lost or locked up in his toolbox. I guarantee you he dont rc anymore.
Old 05-10-2022, 08:40 PM   #17
Tire&Foam Extraordinaire
Nova's Ark's Avatar
Beautiful build and collection of parts! Thank you for sharing it with us
Nova's Ark is offline   Reply With Quote
Old 05-10-2022, 10:08 PM   #18
Thanks Eddie, glad to share, and always happy to use Crawler Innovations products…!
Wish there were more options with the larger ID centers to clear Loaded Dice wheels, but all good.
Old 05-10-2022, 10:29 PM   #19
Aluminum locker shipped from Dlux today.
I was thinking about modifying the skid to get rid of the transmission “adapter” and get the COG a tad lower, but not real sure about the strength of the printed material and don’t have the means to mill a complete new skid out of Delrin right now, so I may just leave it…
Old 05-10-2022, 11:17 PM   #20
PETG holds up pretty good. You can make the print solid or just increase the number of perimeters to beef it up. As long as you design with strength in mind you can make parts that hold up.
Tags
5thd, dlux, shafty, sporty, ssd
House’s 2022 Sporty - Similar Threads
Winter hard 2022 (invernal dura 2022) FREEDOM83 Outside the US 0 01-17-2022 02:52 AM
HTML code is Off
