05-11-2020, 09:30 PM | #1 |
RCC Addict Join Date: Mar 2019 Location: Hemet
| Battery tray?
Now maybe I’m just being whiny, or difficult, or whatever you want to say lol but I can’t believe the Capra has been out since September and there’s no one that makes some sort of aftermarket battery tray option. I know we’re stuck at how wide it can be, but if someone made different bracket to allow a deeper pack I’d be all over it. If I was technologically inclined and had a 3D printer I’d attempt something but I’m not. So I’m ranting about it here instead. Sent from my iPhone using Tapatalk |
05-11-2020, 10:10 PM | #2 |
Pebble Pounder Join Date: Mar 2020 Location: Maine
| Re: Battery tray?
I'm not sure how much deeper you could actually go since the front drive shaft comes quite close to the bottom of the stock tray at full compression.
05-11-2020, 11:03 PM | #3 |
| Re: Battery tray?
I don’t mean deeper down, but deeper as outwards Towards the cab area. There’s quite a bit of empty real estate back there. All it would need is the tray plate that screws in already to be able to adjust a bit further back. But looking at it, that might not even matter because the gap between the cage and the shock tower might not allow any thicker of a pack. I just picked up a turnigy 2s 4200mah 65c that uses bullet connectors and it doesn’t fit because of the connectors. Physically the battery is the same size as the reedy 2s wolfpack. So I’m going to buy some low profile bullet connectors and make my own harness. But I have already trimmed the removable tray portion so my wires and crammed and pinched in there. Sent from my iPhone using Tapatalk |
05-12-2020, 12:06 PM | #4 |
Rock Stacker Join Date: Oct 2008 Location: Long Beach
| Re: Battery tray?
Pop that sliding tray out and see what happens. Maybe it won't allow a bigger pack, or maybe you can run without it and strap the battery to the front bulkhead. Curious to hear what you find. Still building mine and the only battery I have is a 1000mAh 2S pack so it's already dwarfed in there no matter what I do.
05-12-2020, 01:32 PM | #5 |
| Re: Battery tray?
Design one .... have shapeways print it.
05-13-2020, 04:20 AM | #6 |
Quarry Creeper Join Date: Oct 2012 Location: Oxford
| Re: Battery tray?
I actually went the other way!.. Knew I’d be running smaller packs - had a load of 850mah - and wanted to lower the cog... Mk1. http://https://i.imgur.com/kVG8v7O.jpg Mk2 will see the battery moved to between the 2 front wheel wells nice and low still but a lot easier to access! Haha... But yes, you have plenty of space back towards the cab if you can squeeze a bigger battery in 👍 Last edited by stimpy; 05-13-2020 at 04:24 AM. |
05-13-2020, 09:32 AM | #7 | |
| Re: Battery tray? Quote:
Do you plan on putting the battery behind the servo to clear it? I think that may be a better option, too, and that might leave room under the dash for my ESC. Start a thread with this mod or post here please. I'd like to see how it goes. | |
05-15-2020, 03:52 PM | #8 |
| Re: Battery tray?
Hey up.. Apologies was in a bit of a rush last time! I see my link didn't work properly - not sure what I did wrong - very new to pics - not forums!.. As I said my next position will be between the inner arches heading out towards the servo. My 850 packs will fit just up to the last bit of bracing for support. There will need a wee bit of trimming to the cage / bulkhead connections to get the battery flat but nothing drastic!.. Run time... I've only been out with it with the boy and he's always up to something else so I've not actually changed batteries for an hr but id have to guess actual run time to be 30 mins maybe?? I can check next time I go out, though the truck is gonna be on the bench now probably for a bit as I make some changes... Theres some of the build of it on an (ahem) English forum! MSUK - crawler section... Oh, and apologies for hijacking this thread |
Battery tray? - Similar Threads | ||||
Battery Tray | sgtlt | Vaterra Ascender | 10 | 02-03-2019 09:48 AM |
Securing a smaller battery in the stock battery tray | Skroober | Axial SCX10 II | 8 | 12-05-2017 07:15 AM |
Bomber battery tray wont fit new Lipo battery | rock1997 | Axial RR10 Bomber | 10 | 08-20-2016 10:36 AM |
Battery tray & battery options? | Mysterious | Axial XR10 | 10 | 02-18-2012 01:13 PM |
