Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Capra
Thread: Capra Weight Question
Old 02-07-2023, 09:29 AM   #1
Default Capra Weight Question
Greetings all, I'm working on a piece for the website and wanted to see if any of you have the weight with battery for your Capra? Thanks!
s
SteveB1 is offline   Reply With Quote
Old 02-07-2023, 10:31 AM   #2
Ots
Default Re: Capra Weight Question
Mine has a lot of brass parts on it but the Horizon product spec for a new 4WS RTR is 4.5 pounds. It's not clear if that incudes the battery. So figure 4.5 to 5 pounds.
Ots is offline   Reply With Quote
Old 02-07-2023, 10:49 AM   #3
Greetings, I did see the RTR weight from Axial, but I'm mostly curious as to what member's Capras come in at on the scale. I'm sitting at 2677 grams with a 59/41 split, running it as a 2.2" crawler with 13.25 wheelbase.
Old 02-07-2023, 11:05 AM   #4
Ots
That was easy enough - 3.7 kg (8.18 lbs). Don't know F/R split. 4WS conversion and 2.2 wheels/tires.
Old 02-07-2023, 02:45 PM   #5
I'm at 7.85 lbs. 4ws, 14" wb, 2.2, wraith width straight axles.
bgredjeep is offline   Reply With Quote
Old 02-07-2023, 04:57 PM   #6
Ok, good info guys. Helps paint the picture for me.
s
Old 02-07-2023, 05:56 PM   #7
Mine is around 8.5 lbs with 1500mah battery
2.2’s with pretty heavy wheels, 4ws conversion, vp front axle, aluminum body panels, brass front portal covers
islandlife is offline   Reply With Quote
Old 02-08-2023, 08:44 AM   #8
Excellent info all and I appreciate the help. I'll post a link here once I have it finished up to share some of the build ideas and purpose. I'm seeing that many people have converted the Capra into a 2.2", and that also made sense to me. Thanks!
Old 02-15-2023, 08:40 AM   #9
Greetings all, here is the piece on my Capra build. Thanks.!
https://www.mojavevalleyrcadventures...ial-capra.html
Capra Weight Question - Similar Threads
KV Question (Capra) aleckslara Electronics 7 11-25-2021 04:47 PM
Axial Capra Shock Bleeder Screw Question? skinart Newbie General 1 06-19-2021 12:22 PM
Good ways to lose weight from a Capra? TheLetterJ Axial Capra 7 01-26-2021 06:00 PM
Capra Brass Axle Weight Robbob Axles, Trannys, T-case 7 11-09-2019 06:03 AM
wheel weight vs knuckle or axle weight vs creative weight distribution tech712 Axial SCX-10 16 11-04-2014 01:04 PM
