04-09-2016, 11:59 AM | #1 |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
| Bomber as U4RC. Experiences, set ups, tips and tricks.
How many of you have set up your Bomber primarily as a U4 racer? How has your experience been with broken parts? How does it handle? What have you changed about your setup? Any Tips or Tricks you've picked up along the way? Sent from my SM-N910V using Tapatalk |
04-09-2016, 09:54 PM | #2 | |
Newbie Join Date: Jan 2016 Location: Sacramento Area
| Re: Bomber as U4RC. Experiences, set ups, tips and tricks. Quote:
Pretty well after 12 hours of mods. Before that, makes a better crawler. My lips are sealed. Try to get he suspension to work as well as an IFS. Inrease your suspension travel as much as you can while lowering the center of gravity. See you at the track tomorrow. | |
04-09-2016, 11:46 PM | #3 | |
Sent from my SM-N910V using Tapatalk | |
04-11-2016, 06:59 AM | #4 |
Newbie Join Date: Aug 2015 Location: Somerset
get it LOWWWW... i was bouncing all over the place. They just sit to high
04-11-2016, 07:38 AM | #5 |
Quarry Creeper Join Date: Jul 2010 Location: The Ocean State
| Re: Bomber as U4RC. Experiences, set ups, tips and tricks. |
04-11-2016, 11:07 AM | #6 |
Quarry Creeper Join Date: Nov 2014 Location: WA
Just ripped off the ears of my servo in the race yesterday... at least is only $6 a new case. I might look for servo clamp or something like it. My shocks was way too stiff, definitely lower the oil wt from 40 to 20. Thinking in get the prolines power stroke from the slash (front and rear) to lower even more the bomber... |
04-11-2016, 11:41 AM | #7 | |
RCC Addict Join Date: Aug 2013 Location: Missoula
Low, proper shocks (and time/effort tuning) and a sway bar. Night and day. | |
04-11-2016, 11:55 AM | #8 |
I'm running low as I can: I'm debating get the 1283. I have the 1270 which is faster stronger and water resistant. Maybe if I get only the casing of the 1283 can be the way to go |
04-11-2016, 01:18 PM | #9 |
Water resistant is a relative term. I've never had a problem, no waterproofing or anything. Just looked back at pictures, I got the 1283 in October of 2014, and I run my truck 4 or 5 hours a week. Both parts of the 1283 case are different, it's all silver. I went through like 5 1230 fronts before I gave up. Split long ways, or ripped the ears off. |
04-11-2016, 02:23 PM | #10 |
Good to know. I'm in the PNW, all my electronics need to handle rain, otherwise will be a shelf queen. 1283 it is. Looks like I have a 1270 spare for my yeti... or maybe sell it locally. |
04-11-2016, 02:25 PM | #11 |
Pebble Pounder Join Date: Jan 2016 Location: Worthing, England
My HS-7980TH just died, I think water damage as the gears are fine and the motor spins, it just only locks left. And only used a handful of times and not fully submerged. So going back to the WR-7701 servo, and if I can get a replacement Hitec under warranty I will be conformal coating it for sure, an expensive servo thats supposed to be water resistant yet didn't handle a few splashes...
04-11-2016, 03:09 PM | #12 | |
RC Bros Flush Mount 1/10th Servo Clamps | | |
04-12-2016, 08:12 AM | #13 | |
04-12-2016, 11:13 AM | #14 |
04-12-2016, 11:40 AM | #15 |
04-12-2016, 11:54 AM | #16 |
Slash Powerstrokes, fronts in the front, rears in the rear. Blue over Green springs front, Yellow over Green rear. 20wt front, 30wt rear. Front shocks are in the front hole of the rear mount on top, outboarded on the link mounts on bottom. Rear shocks in rear hole of front mount on top, middle hole on the VP trailing arm. Just a little preload on the RR to help with torque twist, along with the Axial Bomber rear sway bar set. Dlux servo mount in the front, all tabs/mounts/plastic cut away until both axles uptravel until the whole housing hits the chassis. As said above, you need to maximize uptravel. Remove anything that touches, including the rear Wraith style sway bar mounts. I'll get some picks at full bump in a minute. |
04-12-2016, 12:07 PM | #17 |
Can you post pics? Sent from my LG-V495 using Tapatalk |
04-12-2016, 12:08 PM | #18 |
04-12-2016, 12:47 PM | #19 |
Maximize uptravel. Axles and shocks bottom out at the same time. Lower links flat at ride height. Rear Front Ride height Outboard front shocks. This is a game changer, seriously. Last edited by maslin; 04-12-2016 at 12:54 PM. |
04-12-2016, 03:35 PM | #20 | |
I'm tired of the leaky (and ugly) stock shocks. Just got a power stroke slash combo. Quote:
in theory the shock is closer to the wheel, so it will behave if had a higher dampening and less travel. That's what you looked for? | |
Bomber as U4RC. Experiences, set ups, tips and tricks. - Similar Threads | ||||
R1 Mods, Tips and tricks | cytogen | G-Made Crawlers | 24 | 12-07-2019 09:54 AM |
Tips and tricks for a newb | cowboy41390 | Newbie General | 4 | 04-01-2014 09:10 PM |
Any tips or tricks.... | suicide_silence | Axial SCX-10 | 2 | 10-26-2010 09:35 AM |
tips,tricks and mods | TOYUTAH | Losi Mini-Rock Crawler | 50 | 12-23-2008 10:47 PM |
