12-29-2015, 05:20 AM | #1 |
Rock Crawler Join Date: Mar 2008 Location: amherst, ny
| Torque twist
Suggestions for getting rid of as much torque twist as possible? I'll be doing more crawling/hill climbs stuff than racing. Thanks.
12-29-2015, 06:52 AM | #2 |
Rock Stacker Join Date: Dec 2015 Location: Cincy
| Re: Torque twist
Stock anti roll bar or one of the 4-5 examples on the market. The crawling performance is much more consistent. The bashing is better as well since you are not fighting the twist.
12-29-2015, 07:19 AM | #3 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| Re: Torque twist
Underdrive gears & dual shock setup or swaybar to tune the twist quite a bit!
12-29-2015, 07:57 AM | #4 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
| Re: Torque twist
So far I have done the OD/UD gearing, added 60with oil on the one shock the twist goes to and added a sway bar. It has helped tons but I still get some on steep climbs. I'm experimentingoing with link placement now to try to dial it in. |
12-29-2015, 09:08 AM | #5 |
Newbie Join Date: May 2015 Location: Little River
| Re: Torque twist
I moved the rear shocks back at the bottom and forward at the top. This realy helped I have a swaybar coming. I was amazed how much the shock placement on the trailing arm changed it! Sent from my SM-G900V using Tapatalk |
12-29-2015, 09:57 AM | #6 |
Pebble Pounder Join Date: Dec 2015 Location: McKinney
| Re: Torque twist
rottenbelly, I am curious to hear about the results of your experimentation with moving the links around as it effects twist. I am pretty familiar with moving links on something like a SCT truck, but I have no idea what to move nor where on a crawler. I have made my own sway bar for now using bits and pieces from other vehicles and I have changed both front and rear to the 43/13 U/D gears, all of which have helped. With that being said I still have quite a bit of twist when the climbing starts to get steep. I will say that sway bars on the back of the Bomber are just about a must. I did loose some articulation but all of the articulation in the world is useless if every time you try to climb something the chassis twists itself into a pretzel. |
12-29-2015, 10:31 AM | #7 |
| Re: Torque twist
Thanks, some good advice. For right now I'll work with what I have. Move links, possibly move shocks rearward, try much thicker oil in rear shocks and/or dual shocks. In the mean time order a rear sway bar
12-29-2015, 12:54 PM | #8 |
| Re: Torque twist
Underdriving the rear (43/13) costs less than $25 and gives more benefits than just reducing torque twist. I'd start with that.
12-29-2015, 01:11 PM | #9 |
Rock Crawler Join Date: Dec 2005 Location: East Texas
| Re: Torque twist |
12-29-2015, 01:38 PM | #10 |
| Re: Torque twist
I put in the dual stage shock pistons with 20wt front and 30wt rear. It did help, especially seeing as how the shocks came only filled half way from Axial. I also built them with no rebound at all so they are pretty neutral.
04-11-2016, 02:40 PM | #11 |
Rock Stacker Join Date: May 2012 Location: Hemet
| Re: Torque twist
Would adding a center drive axle help? I just ordered an SSssd diamond Axle
04-12-2016, 04:13 AM | #12 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
| Re: Torque twist This, and UD rear. Say no more... |
04-12-2016, 05:57 AM | #13 |
| Re: Torque twist
What is an ud rear? Sent from my SM-N910V using Tapatalk |
04-12-2016, 06:28 AM | #14 |
Newbie Join Date: Feb 2016 Location: Edmond
| Re: Torque twist
UD rear refers to Under drive gears in the rear axle, i.e. 43:13 ratio ring and pinion.
04-12-2016, 06:29 AM | #15 |
| Re: Torque twist
But I still Want good top speed I guess u can't have ur cake and eat it too huh haha and the vanquish sway bars are out of stock :( Sent from my SM-N910V using Tapatalk |
04-12-2016, 06:58 AM | #16 |
| Re: Torque twist
You could add tooths on your pinion if you want more speed. I'd reckon an extra tooth would give back the same speed the UD gears are "tossing" away. It's a no brainer solution in my opinion. I'd do the same UD gears on the front axle if this was a go fast-rig, but i prefer having the front axle going just a little bit faster. Helps crawling abilities. BTW I'm using a 0.080 Dlux sway bar. |
04-12-2016, 06:59 AM | #17 |
| Re: Torque twist
Thanks man! Sent from my SM-N910V using Tapatalk |
04-12-2016, 11:44 AM | #18 |
Quarry Creeper Join Date: Oct 2011 Location: liberty
| Re: Torque twist
I am running the Dlux fab Twin hammers aluminum trailing arms in the rear. No anti sway bars. twin shocks in the rear with 45 weight oil in the left rearmost shock no oil in the other rearmost shock. I had a lot of trouble with the 2 speed to get it set up but after adding a good servo saver on the shift servo, it is all good. I am experiencing some torque twist in high gear. But nothing like stock with the single rear shocks and plastic trailing arms. But I am more of a crawler guy. At which the shorter wheelbase in 1st gear the Bomber seems to love the more technical crawling. The Holmes Hobbies brushless system will stand up and talk in high gear. The only loss is turning radius is not as good at high speed although I see no loss in 1st gear I would say. Only my opinion but I am very happy with my Bomber.
04-12-2016, 01:12 PM | #19 |
| Re: Torque twist
I have aluminum lower rear links and all other links are titanium, soon to have ssd diamond center rear axle, vp method beadlocks, pitbull 2.2 tires, hitec high torque digital servo, tekin roc 412 3100kv and a mm pro esc with a kc light bar and proline power strokes with 27.5 wt oil front and rear with green upper springs and yellow lower. Sent from my SM-N910V using Tapatalk |
04-14-2016, 09:28 AM | #20 | |
Rock Crawler Join Date: Dec 2015 Location: Charlotte, NC
| Re: Torque twist Quote:
Torque twist - Similar Threads | ||||
What to do About the torque twist? | m1009cucv | Vaterra Ascender | 4 | 12-26-2014 09:01 PM |
help!-- Torque twist | Tom94offroaduk | Newbie General | 24 | 03-03-2011 04:46 PM |
Torque Twist Q | Brandon13 | Axial AX-10 Scorpion | 1 | 07-04-2009 04:32 PM |
AX 10 torque twist | AX10 trail truc | Axial AX-10 Scorpion | 16 | 01-05-2008 08:51 PM |
