01-18-2016, 04:13 PM | #1 |
Quarry Creeper Join Date: Dec 2014 Location: Sacramento
| nfcrockett's RR10 Bomber Build
I finally got some parts in for my Bomber build. I started with electronics. I'd like to see how the stock parts hold up to the brushless power, I think it will be entertaining. Last edited by nfcrockett; 04-18-2017 at 08:07 PM. |
01-18-2016, 09:19 PM | #2 |
| Re: nfcrockett's RR10 Bomber Build
We should take bets on what'll be first to grenade. I'm thinking the dog bones.
01-23-2016, 12:46 AM | #3 |
I'm going to bet the ring/s and pinion/s. Alright, a lot of progress made tonight. The MMX and pro4hd have found their home! I forgot how much fun it is to do a complete overhaul. It's been awhile since I built my yeti kit. Install vid on the way. |
01-23-2016, 01:37 AM | #4 |
Newbie Join Date: Nov 2004
| Re: nfcrockett's RR10 Bomber Build |
01-30-2016, 01:02 AM | #5 |
| Axial RR10 Bomber Upgraded Electronics 1st Run Last edited by nfcrockett; 01-30-2016 at 01:06 AM. |
01-30-2016, 02:06 PM | #6 |
Kind of a pain making adjustments, testing, making adjustments, testing and repeat. I have been removing the rear shocks, sway bar and the 6 screws for the skid, keeping the front 2 chassis screws in creating a hinge. Took a wraith link and made a kick stand. Last edited by nfcrockett; 01-31-2016 at 11:25 AM. |
01-30-2016, 03:25 PM | #7 |
Rock Crawler Join Date: Apr 2006 Location: Folsom, CA
Why did I never think to swivel the chassis up out of the way?? |
01-31-2016, 12:47 AM | #8 |
Pebble Pounder Join Date: Jan 2014 Location: San Jose
I do wish the bomber had the easy access like yeti xl Sent from my SM-G900P using Tapatalk |
02-12-2016, 07:49 PM | #9 |
Well the plan was to post a step by step install video, that didn't happen. Editing didn't go as planned but any how here are the electronics installed below. During the initial run I noticed I wasn't getting any low end resolution and no where near the torque or speed I get from the yeti, which has the same motor. With the yeti I get buttery smooth low end and all the torque and speed I need. So after tearing the trans apart and rebuilding multiple times, it turns out it's the motor. I tore the motor apart, checked bearings and cleaned. Still the same issue. I assume replacing the rotor may fix the issue. However, I opted to replace the motor entirely. It wasn't easy to decide between another pro4 or a puller pro xl. In the end I decided on another pro4, maybe next time on the puller pro. Future plans include powerstrokes, maddogrc led lights and some vp goodies. Possibly another build after seeing DMG's IS build! Last edited by nfcrockett; 04-18-2017 at 08:08 PM. |
02-22-2016, 08:30 PM | #10 |
Here's a quick update on the Bomber build.
02-24-2016, 08:40 AM | #11 |
RCC Addict Join Date: Jun 2006 Location: Maryland
Like the kickstand hood prop, great thinking!
03-03-2016, 07:09 PM | #12 |
03-18-2016, 03:59 PM | #13 |
| Re: nfcrockett's RR10 Bomber Build: Lighting Setup
Here's the latest update on my bomber build. I got the lighting sorted out. Hopefully I'll get some run time tonight and put the lights to use.
03-26-2016, 08:58 AM | #14 |
| Re: nfcrockett's RR10 Bomber Build: Powerstroke Shocks
Got the powerstrokes mounted. Originally I installed slash rears and xt's. I didn't like the ride height and also the springs on the xt's rubbed the shock bodies too much for my liking. So, I robbed the slash fronts off of my exo and moved the slash rears to the back. Just what I was looking for in ride height. The slash fronts have a lot more room to compress before bottoming out. I used blue springs up front. In the rear, I used red top springs and red springs from the slash front spring assortment kit. As far shock oil, I used 10 wt front and rear. The bomber currently is very light, so the 10wt provided plenty of dampening. I forgot to mention this in the video but since the fronts compress more, you will need to make clearance adjustments. Originally I cut back part of the front bumper to allow the servo horn to clear. However, my front light bar was still in the way. So, I purchased a DCW dewanger the move the servo back. This allowed the servo horn to clear the lightbar. I also threw on my bfg krawler t/a's, which have CI foams installed. With the shocks and foams, I'm able to really see what the bomber has without the stocks foams folding in and launching into a never ending cartwheel. The bomber loves to getting air time. I'm really happy with weight distribution, no more nose diving as with the yeti. I don't know how but I have yet to break any of the stock parts. On the other hand the links are starting to get pretty flimsy, as expected. The front steering links really need to go. With that said expect the links to get replaced in the near future. I'm really having a fun time with this build. I like seeing that stock bomber parts can hold up pretty well. With the yeti it was an immediate money pit, regardless I enjoyed upgrading it. I'm planning on going to axialfest this year. Since the bomber seems to be pretty reliable right out of the box, the girlfriend may get her own to drive at axialfest. Anyway, looking forward to axialfest and another bomber! Last edited by nfcrockett; 04-18-2017 at 08:11 PM. |
03-26-2016, 07:05 PM | #15 |
03-26-2016, 08:58 PM | #16 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
I like how you used the Yeti light cover over the light bar.... nice touch.
03-27-2016, 03:38 AM | #17 |
It's actually a housing I designed and 3d printed to fit over the gearhead light bar. It mounts using the available 4 mounting holes on the bomber. I'll post some pictures with it next to the yeti/exo light bar
05-04-2016, 04:31 PM | #18 |
Pebble Pounder Join Date: Apr 2013 Location: SoCal
do you have a link to the part to mount the lights in the windows like that. I was looking to do the same thing.
05-04-2016, 10:26 PM | #19 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Is that rear light bar mount available yet? And what did you use to clamp around the cage to hold the filler tube up?
05-05-2016, 06:01 PM | #20 | ||
| Re: nfcrockett's RR10 Bomber Build Quote:
I may be able to get you guys some prototypes. I'll have more progress by next week. | ||
nfcrockett's RR10 Bomber Build - Similar Threads | ||||
bilinvic's RR10 Bomber Build | bilinvic | Axial RR10 Bomber | 712 | 04-25-2020 08:09 AM |
Wheelbyte's RR10 Bomber | wheelbyte | Axial RR10 Bomber | 48 | 03-22-2018 10:27 PM |
Rr10 bomber available from tower | jaykim5708 | Axial RR10 Bomber | 12 | 05-05-2016 07:28 PM |
Forestbumpr's RR10 Bomber Build | forestbumpr | Axial RR10 Bomber | 29 | 12-28-2015 09:12 PM |
Bomber RR10 parts | Erik D_lux | Axles, Trannys, T-case | 3 | 12-16-2015 07:17 AM |
