02-16-2016, 11:02 AM | #1 |
Pebble Pounder Join Date: Dec 2015 Location: McKinney
| Has anyone put a front sway bar on yet?
So I have already added my home made sway bar to the rear along with U/D gears front and rear so torque twist is pretty well gone. I am also running Pro-Line Powerstroke shocks, 4" in front and 5" in the rear. Right now I have the shocks sprung and valved very light, mainly because I want to suspension to actually work when running across bumps at speed. I have found that while you will get articulation when set up stiffer, the actual high speed absorption suffers and right now I can run straight across a rough field pretty fast with the suspension actually working pretty well, it no longer bounces all over the place and it moves along pretty well with a Pro4 3300kv and 14/64 gearing on 3s. The issue I have is roll. I am running the chassis pretty low, the front shock collars are all of the way up on the shock body and the rears are only down about 3/8" from the top to keep it level. Some of my roll issues were solved when I went from the stock foams that came in the 2.2 IROK tires to Duece's Wild tall foams, the tires no longer roll under when turning and this helped a lot. Now when I turn a corner it will lift the inside rear wheel but the front axle stays planted so I am thinking that maybe a small diameter front sway bar would help some without loosing a lot of the articulation that it has right now. There would be some loss, but the overall gain could be worth it. So has anyone run a front sway bar yet or know of something that works? Fortunately the stock front shock mount on the axle is already set up for dual shocks so there is a mounting point there, I just need to find a place to mount the bar to the chassis. If someone has already done this though then I would like to see how they did it. Thanks! |
02-16-2016, 12:28 PM | #2 | |
Newbie Join Date: Jan 2016 Location: Germany
| Re: Has anyone put a front sway bar on yet? Quote:
I will add a front swaybar, too. But it is not easy to find points to fix it. Hopefully someone can share his experiences ... | |
02-16-2016, 12:39 PM | #3 |
DLux offers a front sway bar mount.
02-16-2016, 02:02 PM | #4 |
Pebble Pounder Join Date: Mar 2011 Location: Saxonia
simply drill two holes in the bumper and use wraith front sway, exo rear, or whatever you want
02-16-2016, 02:56 PM | #5 |
I am going to take a closer look at it tonight, but thanks Screamer, I did not know DLux offered one. If I can find a way to do it then I will probably just make my own to experiment with like I did the rear.
02-16-2016, 06:22 PM | #6 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
I saw this pic on FB of a home brewed mount for the Dlux sway bar but a wraith or exo bar could work also. It appears to use a couple of parts from an SCX10 Wrangler parts tree AX80123 And as Screamer says there the UCFab brackets from Dlux also, they mount to the front & pick up from the bumper mount. https://dluxfab.ecwid.com/#!/Bomber-...egory=12405705 |
02-16-2016, 06:52 PM | #7 |
Hey altd, I have those part..... |
02-16-2016, 09:06 PM | #8 |
Newbie Join Date: Jan 2016 Location: Sacramento Area
I have the Dlux Universal Sway Bar on the front. It took me a while to figure out how to mount it until I found this picture. PM me if you have questions. |
02-16-2016, 10:32 PM | #9 |
Also at SuperShafty if you were shopping there UC Fab Sway Bar Mount - Super Shafty And another couple of pics that could be useful |
02-19-2016, 03:36 PM | #10 |
Rock Crawler Join Date: Apr 2006 Location: Folsom, CA
I think a front sway bar would be fine for your setup but with a locked front, it will understeer REALLY bad.
02-20-2016, 10:03 AM | #11 |
I think it will as well, but nothing a quick blip of the throttle cannot fix... More than the low speed turning I really need to work on higher speed roll. My steering angle is pretty good right now (I could rub tires until I backed the epa down a bit) so I can live with a little push, I am just tired of having to put it back on all four when I go into a turn a little hot. |
Has anyone put a front sway bar on yet? - Similar Threads | ||||
Dhawk bulkhead with Hotracing front front sway bar | mond | Axial Yeti XL | 7 | 09-19-2015 08:44 AM |
Front sway bar | simpscx10 | Axial Yeti | 1 | 12-29-2014 08:04 PM |
If using single sway bar where to put? front or rear? | ZippoMan | Axial Wraith | 22 | 04-21-2014 08:07 AM |
Install or not? Front Sway Bar | Blinkfan5150 | Vaterra Twin Hammers | 3 | 03-27-2013 03:27 PM |
