Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: Optional upper link positions?
Old 04-28-2016, 08:59 PM   #1
Default Optional upper link positions?
There are 3 positions on the chassis for the front/rear upper links connections (top middle lower). What's the best position / combo for crawling?
Drm31078 is offline   Reply With Quote
Old 04-28-2016, 11:40 PM   #2
Default Re: Optional upper link positions?
That's up to you. I have mine at the top position, front and rear, for better anti squat when climbing or descending. I also feel like it gives better sidehill ability with less roll. Some say it reduces flex a bit but I haven't noticed any adverse affects. If you do move them to the top position at the skid, make sure you look at your pinion angle through the entire stroke. It will change a lot more than if the links were at the bottom positions.
SCREAMER is offline   Reply With Quote
Old 04-29-2016, 01:44 AM   #3
^ what he said lol
moving it one way will give you more squat, causing the suspension to pull down under load, can be helpful as it sucks the CoG lower, can be a hindrance on very steep climbs as it can tend to unload the front end.
other way is anti squat, causing the suspension to separate, basically does the opposite, but either way is a compromise to some degree.
Best way is to try it & see which you like.
altd896 is offline   Reply With Quote
Old 04-29-2016, 04:44 AM   #4
Awesome responses. Thanks.
Old 04-29-2016, 09:53 AM   #5
Ive had no issues with my setup in the middle position. This thread has good info.
Mega Fattie is offline   Reply With Quote
Optional upper link positions? - Similar Threads
sway bar and upper link mount positions drop8950 Axial Yeti 4 04-10-2015 12:38 PM
Vanquish guys.. Need some help with upper positions.. C_Money Axial AX-10 Scorpion 1 07-09-2010 11:41 AM
Your thoughts on upper-link mounting styles/positions... Chadworkz General Crawlers 14 12-09-2008 04:55 PM
Upper/Lower link positions OriginalGTI General Crawlers 5 07-19-2007 08:04 PM
tlt link mounting positions thegodofclod Tamiya TLT Crawlers 1 11-16-2004 02:30 PM
