04-28-2016, 08:59 PM | #1 |
Rock Crawler Join Date: Dec 2015 Location: Charlotte, NC
| Optional upper link positions?
There are 3 positions on the chassis for the front/rear upper links connections (top middle lower). What's the best position / combo for crawling?
04-28-2016, 11:40 PM | #2 |
| Re: Optional upper link positions?
That's up to you. I have mine at the top position, front and rear, for better anti squat when climbing or descending. I also feel like it gives better sidehill ability with less roll. Some say it reduces flex a bit but I haven't noticed any adverse affects. If you do move them to the top position at the skid, make sure you look at your pinion angle through the entire stroke. It will change a lot more than if the links were at the bottom positions.
04-29-2016, 01:44 AM | #3 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
^ what he said lol moving it one way will give you more squat, causing the suspension to pull down under load, can be helpful as it sucks the CoG lower, can be a hindrance on very steep climbs as it can tend to unload the front end. other way is anti squat, causing the suspension to separate, basically does the opposite, but either way is a compromise to some degree. Best way is to try it & see which you like. |
04-29-2016, 04:44 AM | #4 |
Awesome responses. Thanks.
04-29-2016, 09:53 AM | #5 |
Quarry Creeper Join Date: Nov 2010 Location: Queen Creek, AZ
Ive had no issues with my setup in the middle position. This thread has good info.
Optional upper link positions? - Similar Threads | ||||
sway bar and upper link mount positions | drop8950 | Axial Yeti | 4 | 04-10-2015 12:38 PM |
Vanquish guys.. Need some help with upper positions.. | C_Money | Axial AX-10 Scorpion | 1 | 07-09-2010 11:41 AM |
Your thoughts on upper-link mounting styles/positions... | Chadworkz | General Crawlers | 14 | 12-09-2008 04:55 PM |
Upper/Lower link positions | OriginalGTI | General Crawlers | 5 | 07-19-2007 08:04 PM |
tlt link mounting positions | thegodofclod | Tamiya TLT Crawlers | 1 | 11-16-2004 02:30 PM |
