05-22-2016, 12:50 PM | #1 |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
| VP V2 Axle Housing ?
Snapped the stock axle housing today right at the two screws holding the passenger side shock mount. Would like to upgrade the housing to aluminum but would also like to be able to use the stock lockouts and truss until I can afford to upgrade these as well. Will this housing accept the stock truss? Same question about the lockouts. The notching looked much different on the stock housing vs. The V2 and wasn't sure if I would need different lockouts for it. Thanks . Sent from my SM-N910V using Tapatalk |
05-22-2016, 12:53 PM | #2 |
| Re: VP V2 Axle Housing ?
Aren't you the guy that went on a rant about VP being to expensive and not worth it, etc.?
05-22-2016, 01:27 PM | #3 |
Moderator Join Date: Jan 2004 Location: chicago
why not some beeftubes and another plastic axle housing?
05-22-2016, 01:36 PM | #4 |
A long rant also swearing that Hot Racing was good old American made craftsmanship. VP does provide hardware with their OCP axles. I know this was a deal breaker for you as well.
05-22-2016, 01:47 PM | #5 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Yes all the stock plastic parts work on it. Or go with SSD, they include hardware. And its cheaper.
05-22-2016, 01:59 PM | #6 |
| Re: VP V2 Axle Housing ? |
05-22-2016, 01:59 PM | #7 | |
| Re: VP V2 Axle Housing ? Quote:
Sent from my SM-N910V using Tapatalk | |
05-22-2016, 02:01 PM | #8 |
Beef tubes are good, I'm happy with mine for sure. Being able to tighten the screws knowing they're going into steel is a wonderful thing. I'd go with a dlux modded housing with a U4 truss long before an alloy housing. Big inner pinion bearing is all that's needed to keep gears alive and the truss strengthens the housing a great deal while fixing the geometry of the front suspension and dropping the weight of the servo. Absolute win end to end. |
05-22-2016, 02:01 PM | #9 |
05-22-2016, 02:25 PM | #10 | |
Found these for you. They're complete axles for less than $70. This has to be the cheapest out there. They're from the same place as Hot Racing so you're good to go on quality. Different shiny colors if you want too. http://www.ebay.com/itm/Xtra-Speed-A...YAAOSwsN9XB2Vq Last edited by SCREAMER; 05-22-2016 at 02:35 PM. Reason: More contribution | |
05-22-2016, 02:37 PM | #11 |
05-22-2016, 05:00 PM | #12 | |
05-22-2016, 05:03 PM | #13 | |
05-22-2016, 06:12 PM | #14 |
05-22-2016, 06:18 PM | #15 | |
05-22-2016, 06:27 PM | #16 |
I'm not trying to prove anything. You made it abundantly clear before, that price and inclusions are paramount when choosing a product regardless of brand name. You asked for an aluminum axle housing and I showed you the least expensive one I could find which just so happens to include everything. Why is all the other stuff crap? Good to have spares right? Especially when you're basically getting it for free with an aluminum housing.
05-22-2016, 06:29 PM | #17 | |
05-22-2016, 06:34 PM | #18 |
You start asking about beef tubes also. I thought you were looking for the cheapest option again. I'm just trying to help you find what you're looking for.
05-22-2016, 06:47 PM | #19 |
| Re: VP V2 Axle Housing ? Beef tubes make the aluminum, brass and steel. Beef up rc makes the stainless steel. All come already drilled and tapped, just install it and go.
05-22-2016, 06:56 PM | #20 | |
Looks exactly like a factory housing but in aluminum from where I'm sitting. | |
VP V2 Axle Housing ? - Similar Threads | ||||
Axle housing | fshnut007 | Losi Mini-Rock Crawler | 5 | 07-07-2015 09:45 PM |
Using a front axle housing on your rear axle | nstn8 | Axial XR10 | 2 | 10-25-2011 07:32 AM |
Axle housing | nd4spdbh | Tamiya TLT Crawlers | 10 | 08-05-2005 01:58 PM |
